I have just picked up a box of Telam/Polam NOS PCL86 tubes (I got 40 for $60 total)
These are essentially an ECL86 with a 13/14volt heater.
The data sheet for the PCL86 goes to great lengths to disguise the fact that this tube is an ECL86 and can be used for audio. All the measurement points are adjusted slightly and all the detail about audio use is omitted.
But of course all the inter-electrode capacitance readings are identical as are the power ratings.
Is there any reason why this won't make a good audio tube compared to its expensive and rare twin the ECL86?
I have designed a circuit that can use four of these tubes in Parallel push pull, using the triodes as phase splitters, preamp and differential error amplifier in a regulated tube PSU supplying the HT thereby putting all four triodes to good use in the 4 pentode parallel push pull output stage...
If anyone knows why I should now swap these for four ECL86 tubes per channel let me know, because to me I can see (nor hear) no reason to do so except that nagging doubt in the back of my mind.
The Telam tubes are of top quality....
Any advice is of course greatly appreciated...
