PCB for audio amplifier with TDA7250!
Hello friends!:wave2:
I need a PCB for the amp with TDA7250?
thanks and cheers
Hi
I have all the components for the TDA7250 amplifier with output transistors 2SC5200/2SA1943!
Otherwise, this circuit is much LME49811 expensive and difficult to be located?
thanks
Here is the web page.
As opposed to discrete designs, the IA502 uses an IC to drive the power stages.
The entire power amplifier circuitry for 2-channels are squeezed into a tiny TDA7250 10-pin IC. All that's required are four power darlingtons and some passive components to complete a high performance stereo amplifier. No biasing is required as the IC auto biases the output transistors.
The IA502 lends itself well to multi-channel amplification.
A 6~8 channel power amplifier can easily be constructed even by beginners.
IC Chip Amp IA502 (Measurements by RightMark RMAA) - AmpsLab
You will have to ask them about the price for the PCB as it is not listed.
You will need different transisors for their board. The circuit is a little different from yours.
Thanks Ingenieus!
I need PCB (Figure not Picture) for stereo amplifier with TDA7250 with output transistors 2SC5200/2SA1943, not Darligton transistors!🙁
(See schematic above)
