• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
PCB for 6S19P EF184 85A2 regulated supply.
Ive just received boards for one of my projects: A regulated supply with 6S19P EF80/184 and 85A2 (or pin compatible) stabiliser.
Usefull if you need a fixed voltage
Asking €7.50 plus postage, for one board. or alternatively i'll sell you the design files for €5 so you can order the boards yourself from China. this is about €12 for 10 boards from the cheapest source.
Payment via Paypal.
The board is pretty straightforward: size is 75x100mm and mounting holes are 3.3mm on a 65x90mm square.
The board is meant to be mounted underneath a top plate. to achieve this, the unpopulated pcb can be used to mark the drill centers. you'l need a 22-25mm drill for the tube holes.
connections are industry standard 6.3mm fastons: or alternatively you can solder directly to the board.
you can achieve a fixed or supply of 150-350V output with this PCB, current will depend on the input-output differential. The 6S19P is rated for 250V anode-cathode maximum ,100mA cathode current and 11W plate dissipation.
for different voltage requirements some of the component values will need to be changed, i can assist in calculating the required resistor values.
Well it works like a charm!
The TSL100/001 transformer purchased from TME is great for this as it provides 260-0-260 volt, 5V 2A in case you want to do tube rectification, 6.3V 2A which I used for the regulator and 3.15-0-3.15 volt 3A which you can use for your amplifier. sidenote: the 5V and 6.3V share a common 0V, I'm not certain wether you can pull 2A for a rectifier AND 2A for another circuit from this but for me it is of no concern. The HV is rectified with a modified rectifier... 2 diodes would have been fine but cutting off the "-" pin was just easier. This is followed by two 200uF caps. The fuse is bypassed, there is a primary fuse present though. Then the regulator receives the high voltage and filament power. Heaters for the regulator are tied to the regulated B+ in order to never go over the max cathode-filament potential. I'm going to use it to feed the "classic one" project of triodedick
Hi Gideon,
Thanks for the Bump.
On second thoughts, the swapmeet might have been a better place to post this topic.
I only have one PCB left, I have however been working on a version two, and an unrelated version using an EL84 as the pass tube.
Gerbers and Eagle files for version 0.0 are available for free.
Cheers
