pcb for 2xSTK4141V
hy everybody!
I'm building a 4.1 sound system, and I choose to use STK amplifiers.
I've done my pcb for the surround speakers. Can someone tell how good or how bad is my pcb?
I've used the standard schematic for STK4141V.
IMO,STK41X1 series power ICs are good,but not very good.They sound a bit harsh, lack of high freg,and very good in low freg.I think they maybe suit for sub woofer amp.
advice:the output GND of PCB separates with the input GND.
good luck
X.G.
well, i've already done the point-to-point wiring.
actuallly i've already built the pcb for one STK4192 that i'm going to use as subwoofer amp.
the pcb is the one that sanyo reccomends in it's datasheet .
For me, the sound was impressing. I feel that this is the chip-amp I'm going to use.
another problem for me is what filters should I use for satelites and subwoofer?
I've design for subwoofer a 80dB/decade filter using TI's filterPro utility, and for the satelites a 60dB/decade. the cutoff frequency is for sub at 120Hz, and for satelites at 150Hz.
The sum of the signals looks like this:
Hey Guys
Two days ago, I finished my STK4191V after many years of being lazy. It sounded really good at listening tests, but I am wondering if the transformers I used are enough. I have used two 36 volt @ 5 Amp each,two bridges, and two 6800 uF smoothing capacitors, that gives me (+36 volt @ 5 Amp) and (-36 volt @ 5 Amp). I am driving 8 Ohm speakers, I just want to know if that is enough for this STK.
The PCB was a ready made one, bought it from Mr.Lumanauw from indonesia, the layout looks like the one stated in the datasheets. I had no oscillation problems, so that was a good enough result for me, because when I used veroboard I had notorious oscillations.
Any questions,I am here for you guys
for my stk4192 i used +-22V rails for testing.
It was clearly not enough, and now I bought a toroid with 2x25V secondary. That means around +-35V no-load.
I think this would be enough.
About your amp, i think that it's enough 2x36V .
Still, stk4191 is rated to Vcc max +-53V. It's about the power you think you need. Personaly, I think that +- 36V is enough for your amplifier.
Now, can you please draw a scatch for me?
You are saying that for every cap should i have a different trace to the ground? I'm not sure I did understad clearly.
I've drawn a scatch using paint, and now this is the layout(the condensators were replaced only by one larger condensator)
where in this layout should I put the ground for the input?
Thanks for your reply!
Regards!
building the PCB
lately, i was busy having school exams....
but, this is wat i've built untill now.
:smash: :smash: :smash: :smash: :smash: :devilr:
now one of my satelites:
two satelites, staked:
point to point wiring.....
I've finished my amp....
now, i have aproblem. on all 4 channels I have high frequency oscilations...
I've already blew 2 tweeters...:hot:
what can be the problem??
i've used the schematics presented in sanyo's pdf..
can the cause be because of the long wires to my soundcard? (tghe wires between my computer and the soundcard are aprox 8 meters long)
should I place some 300pf in parallel with the reaction resistors? would that elimnate the problem??
