I suggested a 24/96 TAS1020 based USB interface on the support forum a while back. I have an older Audiotrak optoplay and the board is tiny and simple with minimal component count.
I assume with the Centrance firmware that Lavry and Benchmark also have licensed for their TAS1020 USB interfaces this should not be too hard.
Of course this should come after the release of the AC1
Cheers
Thomas
Cheers
Thomas
Joshua_G said:Texas Instruments TAS1020 is obsolete.
TAS1020B is not, however.
Hi, can anyone tell me the the name of the new revision S/PDIF receiver? Also the current draw on the digital rail? Thanks in advance.
Not sure what new S/PDIF receiver you mean.
I think many of us are interested in a USB/firewire converter for our beloved buffalo.
The subject is a bit off topic, even if the chief moderator started with it.
The *recommended" belcanto device is expensive, uses an old chip and is not future proof, no 192khz. Then there is also the USB/firewire discussion. The Weiss converter is even more expensive. At the moment I would use a cheap usb converter and ..wait, or probably you can find a M-Audio or Edirol firewire device, then you have an additional AD converter with a mic preamp for the same price as the belcanto.
regards Andre
rolls said:
... uses an old chip and is not future proof, no 192khz. Then there is also the USB/firewire discussion. The Weiss converter is even more expensive. At the moment I would use a cheap usb converter and...
My thoughts precisely. I can't believe people still use a chip that is almost 10 years old... I'll stick with the PCM270x until something more modern shows up... With regard with the other solutions I think they use ASIO drivers which I think iTunes cannot connect in Windows and I like itunes too much to give it up. So keep on waiting...
I don't know if I would be that optimistic... I'm currently trying to source a WUSB chip for a specific product and it seems that it's impossible for a startup (not even talking about a single DIYer) if you're mentioning quantities of less than 10k... =(
But WUSB chips have been in full production since early 2006, so go figure... You need to go through NDAs and some proprietary "qualification" procedures to even get on the list of companies they woudn't mind selling 10k+ units to.... =\
maybe this could be interesting:
http://apple.clickandbuild.com/cnb/...s-null&prodCategoryID=75&title=FT4232H+Module
chip description is here:
http://www.ftdichip.com/Products/FT4232H.htm
the two channels with mpsse (multi purpose synchronous serial engine) can handle up to 30mbit/s and probably implement i2s easily?
the eval module is imho damn cheap and the offer a lot of example source code, quite contrary to other manufacturers...
A generic USB chip is probably a bit far from the target. Writing an USB audio stack interoperable with MacOS/Windows/Linux drivers might take a while.
The benefit of a TAS10120 is that the USB audio stack exists and has been tested and debugged for a while.
Cheers
Thomas
Cheers
Thomas
my hypothesis reads as follows: the chip operates on a 12 mhz clock, as far as i remember with internal pll generated 480mhz. this clock is supplied to the uarts/mpsse by dividers. because 44.1k will require non-integer divisors it the outputted serial clocks will probably not be very clean...Very interesting stuff! But are you sure it can output i2s, and with a clean clock...?
in the case of the buffalo with its internal dpll i doubt this would cause problems.
the question of drivers is another issue. because it's so damn cheap i will order one and do some experiments with python and libusb. for simplicity reasons (using linux here).
The MAudio Transit USB is mentioned in the article as using t he TAS1020 and feeds the to a AKM4585 . Uses a driver program to install.
My interpretation of what the author of the article said was that he really couldn't tell any difference in sound between the belCanto and the Transit...
BUT, lots of driver issues- especially with Mac...
http://www.amazon.com/M-AUDIO-Trans...dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
BUT most of the problems are from older reviews, newer ones seem to be positive generally..
On the other hand, this has great reviews as far as drivers go:
http://www.amazon.com/Edirol-UA-1EX-USB-Audio-Interface/dp/B000BD1AF0/ref=cm_cr_pr_pb_t
Wonder what chip it uses..
- PC Based
- Pc -> Dac, How ?
