Pavel Dudek's super Gainclone group buy
Colour of the pcb
  • Black
    Votes: 31 37.8%
  • White
    Votes: 12 14.6%
  • Red
    Votes: 14 17.1%
  • Blue
    Votes: 13 15.9%
  • Yellow
    Votes: 3 3.7%
  • Green
    Votes: 13 15.9%
  • Total voters
    82
Bridged operation, differential in.
Hi!
Happily awaiting the PCBs, in the meantime, planning my build:
1.
I would like to build this PCB for bridged operation driven by one differential input. Would the attached connection be the way to go? Ground is audio ground, not pin 1 on XLR which goes to chassis ground.
2.
I have a +/- 32 V PSU box. Could I power the gainclone from this instead of buying more transformers? Would I connect it directly to the big filter capacitors?
Best regards!
I have a nice pile of green and golden pcb's.
peranders I am finally building the board (the red one)
Would you mind explain the large amount of parallel resistor installed at the output of the op amp and the ones at the bypass. Wouldn't they replace it with one high quality resistor even better (e.g caddock MP 0.1R )
