Yes, it is. It passes (pun intended) all the definitions of class A single ended. It consumes all the current all the time, and signal goes through one active output device, tube or solid state. Does not get anymore se.
BA-1 vs Aleph
@ WDECHO:
if you care to comment: which size Aleph did you have, Aleph30 or bigger? and how do you find the sound in comparison to your BA-1 with BA-3 FE? & how much power did you get in that BA-1?
p.s. btw there is a renewed interest in F3 since Papa is giving away some LU jfets, so to benefit those folks you might want to include a word on it as well.
@OP: ACA is definitely the best starting point to get a taste of it before scaling up to more heat, weight and $s (which is almost inevitable now that you have come to Pass forum 😉).
@ WDECHO:
