Passive Crossover for Passive Subwoofer?
Hey
Is it possible to design a passive crossover to a subwoofer that has a different orders in it...for example I want to make a passive crossover that has a 2nd order highpass @ 18hz and a 4th order low pass @ 80hz
I know its possible to make them the same for example a 2nd order bandpass at 18hz and 80hz?
If any more info in required just ask
any responce to this would be appreciated or even a referal as this is a complicated subject
It is possible, but the cost, size and weight of the huge inductors and caps required would be very large, possibly more than the cost of the rest of the driver and cabinet put together. It may seem complicated, but active is the way to go with subs.
I'll second PM, the inductor for a 18Hz highpass will be extraordinarily expensive,
if you could even find one, the 80Hz components will also be expensive.
Active highpass (and lowpass) is the only sensible option.
There is no problem with 2nd order highpass and 4th order lowpass.
🙂/sreten.
I know how active crossovers work and that they are more efficent and make the amp more efficent which makes less distortion but i dont know how to make them.
Can any of you direct me to a book or site or even a store bought one that could me make them or buy them
thanks
Could I pay possibly pay you to design and/or make one for me
(with my predetermined specs that ill tell you if you accept),
or could you direct me something that can
please!
nothing comes up on google anywhere that I can use
and I cant use yours cause there for speakers and 2/3 way ones..I want a 1 way bandpass if that possible
There used to be a kit for use with Electronics Australia's Playmaster series. IIRC, it had three op amps and gave stereo hp outputs, a mono sub output, and came with instructions for adjusting crossover frequencies. Jaycar don't seem to have it, must be Dick Smith.
Toast_Master said:
could I change a certain thing on it to make it 18hz? cause if so then my search is over
Yes you could. This is a silicon chip design and AFAIK such kits come with the original article which means you will get a schematic and detailed explaination and instructions. Even if it does not tell you how to make the exact change you want, you should have plenty of info with which to work it out.
thanks for help
would it be an easy change though? would I have to change many things because changing one value would change the effects all the other components have on the crossover
so the actual kit may come with an instruction book saying other modifactions that you can do?
