Pass X150
I am expecting an X150 to be delivered Wed. or Thur.
The seller described it as being upgraded. When I asked how it was upgraded he said that the transistors have been replaced with currently used transistors. Would not other parts need to be replaced if this were the case? Current models are X150.5 and X150.8. It is my understanding that there is more than just different transistors used in these current models.
Would these currently used Transistors be compatible in the older circuit design?
Tom
Who knows? I am not aware of any upgrades, particularly ones involving
replacement of output devices. The only changes historically have been
from TO-3 cases in old models to TO-247 cases currently used.
Newer models have changes to the topologies, but again, there is no
information on what might have been done to the unit.
You can always arrange for Pass Labs to look at the unit.
Well, I've been listening to the X150 for a couple of days now and I must say it is certainly is a big step in the right direction from my Phase Linear 400 and B&K ST1400 Series II.
I am very pleased with the way this amp sounds powering my original Snell Type A speakers. I am using an Oppo 105D running through my Odyssey Candela preamp and everything seems to be happy playing together.
I no longer care if transistors have been swapped or not. I am happy with what I hear and that is pretty much all that matters.
I must say that being an entry level piece of Nelson Pass designed gear I am duly impressed. Maybe one day I will be able to afford another Pass creation.
Thank you Mr. Pass, for this amp is bringing me great pleasure.
Tom
I sold mine to a guy and he can't turn it on. Blowing fuses. It (and the second one) did it at the house of the guy I bought it from. He eventually turned it on. They have auto 16 amp fuses, and mine is the old school disposable 16 amp where it worked. What to do?
so , to recapitulate , because I'm confused:
- you bought two , one with "automatic fuse" (current limiter ) and second with old school melting fuse;
-you sold that one with automatic fuse , and even if it worked at your home , now it is not starting on - in Italy?
The guy I bought FROM had 2. Both turned off the lights in his house but turned on eventually. I bought one. He had auto fuses in his home - the ones that reset with a switch. Mine worked well with ancient screw fuses. The guy who bought it from me can't turn it on.
well...... if it worked , and now is blowing 15A fuses repeatedly , nothing can be done remotely .... especially remotely^squared
it must go to bench, first PSU needs to be checked
Dodo cap or diode bridge is nothing unusual after few decades worth of powering on surges
