So, the X150 (without cyclops meter), I want to know all about it.
Where does it sit in the layout of Pass amps ?
Whats the consensus re its sound character ?
Rough idea of build dates vs serial number ?
Any info on bias setting ?
Modifications, etc and so on....
Thanks all.... 🙂
Thanks all.... 🙂
some things you can read in xa_paper.pdf at PL site , some things you can/must ask them
anyway - worth mentioning - there is Official PL Disposal Facility , if you became tired of these lousy amps
Pretty much at the bottom of the X series, not to say that it isn't perfectly
serviceable.
From what I understand though, being at 'the bottom' only really refers to the power output, where as the sound 'signature' stays the same through that models range.
Is that correct ?
If so, how would one describe the sound (or lack off) of the X series vs maybe something a bit latter ?
Guess what i want to know, is, if the chance came up to buy an X150, would i be mad NOT to grab it ??????
Is that correct ?
Hmm, cant edit above post...
I can't seem to find any info as to whether the x150 has any sort of speaker protection.....
turn on delay, shut down anti thump, dc, clipping, over heat...
Any info on this people ????
Is that correct ?
don't be picky ; keep old one , grab new one too
overheat yes , other protection(s) aren't needed with these amps
LOL, Oh ZM.
if i had that sorta money. well, why stop at two ?
so theres no 'strange' output swings as the supply rails collapse on power off ?
All the questions are because I cant afford to buy one, then find out a later one is far superior..
Its only something i can do once...
and not being near the seller, I cant just go there and have a listen..
A big dollar item, sight unheard is a very hard decision.........
you can't go wrong with either of them ; same philosophy , same approach - just few years of difference between them .
as with everything in life - there is a difference but which one is better can be easily just matter of personal preference
don't bother to read what regular Greedy Boy in Papaland can tell - they're all chasing each new Papamp as best thing after bread , claiming that that one will be last they gonna build ( at least in this year)
buy cheaper one , give 20% of difference for music , 20% to buy some parts ;
listen that cheaper one , enjoy in music and build your own Papamp , having fun in learning and building
and yes - use best speakers you can buy/make
Mmm yes.
Thank you 'Papa' and ZM..
Rare to find a voice of reason and reality these days.
As much as i want this amp, I think my money would be better spent on speakers...
right, so.
Im now the proud owner of a 2003 model x150...
Yay me.
just gotta wait for it to be freighted interstate to me.
meanwhile i'll start designing the new 'table/rack' for it sit on..
ohhhh im broke but excited......
Yay me.
Thanks ZM.
Was a BIG bullet i just had to bite...
Now, is there, somewhere, anywhere, a circuit diagram, and or at least some info on bias settings ?
I know about Mr Pass's post on heatsink temperatures, but surely theres an actual bias adjustment...
As far as I can find out this unit has never seen a service, I'm not saying it needs one, but I'd like to know I have the info if needed..
I come from an electronics background, so the geek in me 'needs' to know and have the info, even if it never sees light of day 😀
Daym ZM.
You are a wonderfull individual.
Many thanks...
Still slowly reading the owners manual.
Almost sounds like a version/refinement of the quad current dumper design.
Many thanks...
exactly !
they are the same - both have input and output terminals
😀😀😀right, so.
Yay me.
Could you please post your exact address
Allarm Pin code
And exact date of your next Hollidays
sure, no problem, I'll leave the key under the mat for you.
make sure you bring someone strong.
I wont be having holidays for a looooooong time now.
not that ive had one in the last 10 years anyway....
this is what im calling my mid life crisis.
why buy a sports car (i did look for cheap second hand ones, lots out there too)
when i can have a 'Pass'.
- Pass X150 Where does it sit in the overall line up ??
