Pass B1 pre with BF862
Output noise = Stage gain * sqrt(bandwidth) * Ein
If Ein is 1.2nV/rtHz and the stage gain is 1times (-0dB) then for a 20Hz to 20kHz bandwidth the output noise due to Ein is:
1 * sqrt( 20000 - 20) * 1.2 = 1* 141 * 1.2 = 169nVrms
Now compare to a power amplifier with an Ein = 10nV/rtHz and a stage gain of 27times
Output noise due to Ein = 27 * 141 * 10 = 38070nV = 38uVrms ~ 0.04mVrms
2 Stage B1 with BF861B and BSC network
Dear diyers,
I was thinking of building a 2 stage B1 with baffle step correction between the stages. Please see attached diagram. I have built the B1 with LSK170 and I am very happy with it. For this project I wanted to use BF861B's (Vds max 25V, Ptot 250mW max, yfs 16-25mS), selected for about 10mA Idss, upper JFET Idss a bit greater than lower as per post #35.
In practice, R1 in the comp network would be DIP switched series resistors of 1K, 2K, 4K and C1 DIP switched parallel caps of 0.01uF, 0.015uF and 0.022uF. This should give a nice set of possibilities with fz about 300Hz to 2kHz and A 0dB to about -6dB.
As you can see, I was intending to DC couple the two followers - the 9V (approx) bias is already there for the 2nd stage.
Any comments before I commit to making this would be appreciated. Will it work?
Thanks.
