Parts needed for 3A amp. project
I'm building an ESP 3A amp. and I could use a couple items to upgrade and i would rather not place a forth minimum order. I need 4 -100 pf. polystyrene caps, 0.5 ohm non inductive 5 watt resistors ( ideally 1 percent), a killer pair of input caps (2-5 uf).
I will buy or trade for your needs. I do have some Dale RS-5 watt one ohm, 0.1 percent factory resistors. Good for calibration, etc. I also have a Belles model two amp. chassis. It has heat sinks on both sides for a total of eight T-03 output devices. Complete with RCA's and binding post, electrolytic caps.
Thank you,
Mike
