Parasound HCA-1200II different output transistors variants???
Hello everyone, i come across Parasound HCA-1200II amp,really like it but find out it has Toshiba 2SA1553 and 2SC4029 output transistors. In service manual, only one i have found and get from Parasound service (they said they don't know anything about this old amp..), output transistors are SanKen 2SA1386 and 2SC3519.
And BIG QUESTION, is there two variations of this amplifer in production or someone messed it up????
John Curl, everyone...help
Most amplifiers are very tolerant to what output devices go in them. As long as the voltage rating and SOA aren't exceeded just about anything will work. In more modern amps the speed of the output devices can be an issue too. Negative feedback keeps everything working as it should. Input stage and VAS are more particular.
Bias current is pretty much the same for any output devices. 65mA / device is almost standard for BJTs with proper neat sinking
Yes it's fast, but it is slower than that SanKen ones,does it have negative influence on amplifier stability and sound quality?? Parasound represented this amp and HCA-1500II (vitch have this Toshiba transistors as output devices in official service manual) as "50Mhz 15A output device" amplifiers. Is that statement suported by this data abouth Toshiba 2SA1553 and 2SC4029??
Yes, maybe it's ok,but i would like someone confirm to me there was original/regular production of this amp with this Toshiba transistors,or someone with same configuration. I com across one old thread where someone has problem with different current reading from one channel, all 10 transistors given different values. Other channel was good. He posted table of reading with this Toshiba transistors, but that topic is closed
https://www.diyaudio.com/community/threads/hca-1200-ii-bias-and-output-relays.227313/
