Paradise phonostage pre-regboard, psu group buy v2
I still have a pair of stuffed Paradise boards to sell. They are working and calibrated.
The PSU shunts are missing. This is a speacial version for people that wand tu use their own PSU.
Off to Les's to pick up 50 cap6 boards this afternoon. I've ordered 75 traffo/choke boards and can always get more cap6 from Les for any stragglers.
Anyone on 110V will have to cut the track on the back of the pcb that links up the 230v winding. It's obvious.
Cheers Keith glad they arrived in a timely fashion.
Here the BOM that I use.
2x Talema 70065k transformers: https://www.electronic-shop.lu/EN/products/133830 RS doesn't have them on stock until January !
4x Epcos TDK 82uH common mode chokes: http://www.mouser.co.uk/Search/Prod...virtualkey59250000virtualkey871-B82724J2501N1
8x LQA10T300 high speed zero recovery diodes: http://www.mouser.co.uk/Search/Prod...T300virtualkey59040000virtualkey903-LQA10T300
16x 0.1uf (100n) wima caps: http://www.mouser.co.uk/ProductDeta...=sGAEpiMZZMv1cc3ydrPrF7l45uRd9dVhK2iviYXLQ3E=
4x Caddock, 20 ohm, 30 watt thick film resistors: http://www.mouser.co.uk/Search/Prod....0-1%virtualkey68400000virtualkey684-MP930-20
4x Hammond 158T 300mA chokes: https://www.jukebox-revival.eu/staging/smoorspoel-hammond-158t.html
I snub the diodes with 10n styrene caps under the board from rush-online.co.uk, no need for resistors due to the proximity of the 20r Caddocks and the coil impedance.
EU buyers will likely need different dropper resistor values, as will our U.S. cousins.
