Paradise Builders
Does the output voltage fluctuate when you blow air on the input stage? It could be caused by the air around the transistors changing in temperature
It actually have a lot of impact, to blow air onto the boards, on the input and even more so, on the mirrors, so i will experiment with thermic shielding/compensation. Thanks for the input:)
Joined 2005
Yes, there is some background work ongoing, to translate the assembly guide into german. Sorry I would have done it myself but I figured you would want to have your boards quickly :D
It makes a lot of sense, given that a large number of boards actually goes to Germany.....
By the way, the first batch of boards + components is out the door, was picked up today. I think I can send the rest out this week, since next week is Electronica trade show here in Munich, and I will be busy.....
