Papa, Watt's next?
Nelson,
When you first introduced the P1.7 we had a preamp and an unbalanced to balanced converter. Is there a JFET device which can also serve as an unbalanced to balanced conversion device with some gain. Many of the amp projects are balanced design and I do not want to use a transformer or Op-amp.
After reading the Earth Times article I wonder if I should transfer some funds to SemiSouth stock.
Tad
The M2 remains under wraps, since I do not wish to have
too many things distracting the marketplace at once. My
Japanese distributor apparently wishes to release it, and
their wish would make it so. It is possible, however, that it
will only be available in Japan in the near term.
