Panasonic PT-L595U Retrofit
OOPS... the projector is an olympus vp1 - now out of production, but it's a GREAT projector (very small) - it's really a shame that a simple lamp can make it obsolete!
If anyone figures out how to do a retrofit for the lamp or at least how to make it turn the image on, please post it here.
thanks!
HOW DO I TRICK THE BALAST ON A POLAROID POLAVIEW 350I
Hi, everyone
i have a Polaroid polaview 350i projector.
i would like to trick the ballast into thinking there is a working bulb.
a lot of people are saying that there is three wires coming out of ballast, +5 volts, signal & ground.
i do see a small plug coming from the ballast to the main board,
one wire is brown and the other two are Grey.
if these are the wires that people are talking about, what do i set my digital meter on, i have one of those cheap red one`s from harbor freight?
what two wires do i jump?
do i leave the connection plugged into the main board?
do i cut the two wires that i`m suppose to jump?
thank you
what is the difference between a UHP & UHB bulb
Hi everyone,
my polaview 350 projector uses a 150 watt UHP or UHB bulb,
i was wondering if someone can tell me the difference.
which one is better.
how do i know if it is AC or DC volts.
thank you
