pa2030a sub
not sure if this helps, but the tda7560 is supposed to be the same as the pal007a i know personally, i have swapped between the pioneer pal005a, pal007a, and pal007b, maybe a few others i can't remember, but no newer units from the past 5years, or so.
There is at least one version of the IC 'marked' PAL007B that is NOT the same as the original PAL007B. The last pin is a 'clip detect' pin instead of an HSD pin. If you get one of those, the remote will not work. The IC I suggested will restore the remote output function.
The following is one example of an IC with the same pin configuration but with the CD pin instead of the HSD pin.
http://www.audiosound.info/katlisty/TDA7454.pdf
There is also the TDA7386 that has either a very weak or non-functioning HSD output (I don't remember which).
oh, no...... how can you tell the version of that one? i have not bought the st before, just the pioneer replacements, though i just put an order in for the st's, and pioneer only offers the 007b's as the current sub. though, i think they would be selling the ones with hsd, but i don't want to end up accidentally buying the different ones in the future...
