PA-315 speaker
dwhissel
2013-02-15 7:34 pm
Has anyone had experience with B-52 PA speakers? I am in the process of putting together a sound system for our church P & W band and am leaning toward a 3-way passive speaker system. We do NOT rock the walls with dB since it is a small room; about 55' square. The PA-315 looks like a possibility??? I plan on running an analog AB class PA amp. Thoughts...?
dwhissel
2013-02-15 7:34 pm
All instruments; either 1 or 2 acoustics, usually a bass, and a keyboard. At any time, 3 instruments and 4 voices. This system is more of a sound reinforcement than a primary amplification system. As stated before, we don't play really loud. Typically there may be 100 people at a service. Occasionally we may play before 150 to 200 people. My main interest is getting feedback on the B-52 line...specifically the PA-315
If its sound reinforcement you are looking into, make sure you have multiple speakers that handle different frequencies (for example sub, bass, mid, high)..
It might be worth looking at some JBL JRX 215's as they are a great 3way system. Even though they use 2x 15's the lower 15 is filtered to handle more bass (as with the upper 15 handling more mid)
[IMGHTTPDEAD]http://evenstadmusikk.no/images/mamut/lrojbl-jrx125.jpg[/IMGHTTPDEAD]
Thanks for the input. I take it then you've heard these?
Your welcome! I have the JRX 115's (the model without the bottom 15) and they take such a beating as well as sounding very clean in comparison to others in the same league!
They have a huge crossover that can handle a lot of power for a long time, and of course being made of wood the cabinets both look and sound good!
However, they are heavy!!! VERY heavy.
have a look>>>
JBL :: Product
SPEC SHEET:
http://www.jblpro.com/BackOffice/ProductAttachments/JBL_JRX125.v1.pdf
