Overheated brain, anyone else?
I have maybe ten tube amp projects (some may be scrapped), 3-4 SS projects and 1-2 hybrids.
Add to that two synthesizers I am "repairing/refurbishing", another three synth kits "in progress" (thanks Chromenuts!) and some 15 (or so) DIY synth modules and 3 sequencers ...
Then there all the small projects like stuffing a classD-amp into a box, finally fixing a timer for a crappy digital camery to use it for time ...lost the word - take one shot every minute, etc.
Time Lapse
My brain overheated causing a blown HEAD gasket. This allows the oil and water to mix and both get pushed around by hot exhaust gas. Now all the projects get scrambled together and none of them work. So, why is there a VCO in my tube amp, and a 5AR4 in my battery powered music synthesizer? Nevermind, I'll just play my guitar.......Now, is that a chord, or a cord?
Stack overflow, System halted! Remember DOS?
Why do you think speakers come in pairs? One to "finish & the other set to languish unfinished as we move on to other ideas.
--------------------------------------------------------------------------------------------------------------------------------------------------------Rick...
While I´m building projects,My brain is constantly thinking of other projects to build...
And the result is lots of unfinished projects to build....
Anyone else have this "Problem" ?
WHICH problem?
That is the DIYer NORMAL state of mind.
Unless he´s here to argue capacitors, cables or UFOs, those never actually BUILD anything, their thrills come from other sources 🙄
