I have an old, broken but beautiful 50's radio that I'm replacing the electronics in. Unfortunately the speaker paper cone has a hole in it, and I need to find a modern replacement *.
What is the best option? I'm thinking a small oval fullrange driver, since that's what the radio was made for. I will replace the baffle so the exact measurements isn't an issue.
However, I would like to get as good a frequency response as possible. The enclosure is approx. H30, D20, W40 (centimeters), and it is totally open; that is, the back is full of holes, there's a rocking lever switch mechanism sticking out, there are some weird hole for a radio antenna, etc.
Questions:
(* The old one was a 15x21 cm oval Isophon with square outline mounting holes, approx. 13.2 cm between the hole centers. I don't think it's possible to find a replacement, and I'd rather go for something modern with better frequency response anyway)
Questions:
- The open enclosure will probably yield a horrible response right? Would I be better of building a small closed or bass reflex box inside the original enclosure?
- If not, what can I do to make the response as good as possible?
- What would be a good, cheap driver?
Something like this :-
PIONEER TS-A6813I 6 X 8 CUSTOM FIT SPEAKERS on eBay (end time 21-Feb-11 17:44:32 GMT)
andy
andy
Maybe a picture or two would help also. There's someone I know with a few of those kinds of drivers. I'll see if he's available. 😉
Sounds like you have a radio similar to my AGA.
If you're interested you can check this Vintage AGA Radio - Minhembio forum
That particular isophon is not all that rare, don't know if i have a single or not. I do have 2 singles of the larger coax.
I also have at least 2 drawers of smaller ovals.
For a modern driver, a car driver designed to mount in the back deck koading into the trunk will likely work best in your open back box.
Pictures?
dave
Pictures?
dave
Sorry to go OT on the thread, but your problems with the noisy pots are probably due to bad capacitors. *DO NOT* run the radio until you have replaced *all* of the capacitors with paper insulation. The tubes are probably OK.
- Full Range
- Oval speaker for old radio
