Oval speaker for old radio
I have an old, broken but beautiful 50's radio that I'm replacing the electronics in. Unfortunately the speaker paper cone has a hole in it, and I need to find a modern replacement *.
What is the best option? I'm thinking a small oval fullrange driver, since that's what the radio was made for. I will replace the baffle so the exact measurements isn't an issue.
However, I would like to get as good a frequency response as possible. The enclosure is approx. H30, D20, W40 (centimeters), and it is totally open; that is, the back is full of holes, there's a rocking lever switch mechanism sticking out, there are some weird hole for a radio antenna, etc.
Questions:
  1. The open enclosure will probably yield a horrible response right? Would I be better of building a small closed or bass reflex box inside the original enclosure?
  2. If not, what can I do to make the response as good as possible?
  3. What would be a good, cheap driver?
(* The old one was a 15x21 cm oval Isophon with square outline mounting holes, approx. 13.2 cm between the hole centers. I don't think it's possible to find a replacement, and I'd rather go for something modern with better frequency response anyway)
That particular isophon is not all that rare, don't know if i have a single or not. I do have 2 singles of the larger coax.
I also have at least 2 drawers of smaller ovals.
For a modern driver, a car driver designed to mount in the back deck koading into the trunk will likely work best in your open back box.
Pictures?
dave
Elmers white glue is a godsend to paper cone repair if the spider and voice coil are ok ...if not then a modern car driver may be your best option cheaper the better as newer high wattage drivers may be inefficient...
E
