Oval driver line source
After a long time as a spectator, I'm starting a line source project. The driver parameters measured in REW are the following:
They are Sony almost oval TV drivers and measures approximately 105mm x 50mm or 4 1/8” x 2”. With the parameters, I defined a volume of 2 liters per driver because increasing the volume has little impact on the response. As illustrated in the above image, the active area of the speaker measures 82mm x 39mm.
In VituixCAD, should I simulate it as a circular driver with Dd=82mm (largest vertical dimension) or as a rectangular driver with Height=82mm and Width=39mm?
20 DRIVERS - 106mm CTC - CIRCULAR.jpg 20 DRIVERS - 106mm CTC - RECTANGULAR.jpg
Update:
Later, in post #50, I demonstrate that these first simulations were wrong.
In short, in the diffraction tool (F4), place only one driver. From the data obtained from this driver, the program simulates the results for the arrangement of the various drivers that you place in the driver layout tool.
Reactions: NeonDriver
I continued simulating as rectangular drivers.
With 20 of them arranged vertically in a line, with 106mm c-t-c because of the edges, without equalization, filters or power shading, the resulting graphics were these:
baffle 1.jpg20 DRIVERS - 106mm CTC - 0mm OFFSET - DIFFRACTION.jpg 20 DRIVERS - 106mm CTC - 0mm OFFSET - GRAPHICS.jpg
To reduce the c-t-c distances to the same dimension as the vertical length of the cone (82mm), I arranged 25 drivers alternately. The SPL graph improved and the vertical directivity graph was surprising:
baffle 2.jpg25 DRIVERS - 80mm CTC - 51mm OFFSET - DIFFRACTION.jpg 25 DRIVERS - 80mm CTC - 51mm OFFSET - GRAPHICS.jpg
From the graphs, the offset configuration presents the best preliminary results. I didn't expect that. Has anyone ever tested something like this? What are the pros and cons?
In the sims, you just decreased the c-t-c, but haven't taken into account the offset of the c-t-c (and I'm not familiar enough with the apps to try and simulate that, if even possible). So, of course, we see a lot less comb filtering at 82mm, instead of 106mm.
Also, wouldn't the c-t-c be the diagonal between the drivers?
Again, way over my head regarding simulations of offset drivers in a line.
Reactions: thalesdecastro
that clears it up, thanks. Learned a bit more about VituixCAD.
If you wanted to really cut the c-t-c distance, you could place the drivers horizontally instead of vertically, but that means you will need a lot more drivers to achieve the 75% coverage between floor and ceiling to get mirror images. And a lot more work for wiring them up! 🙂
View attachment 1327422View attachment 1327415 View attachment 1327405
View attachment 1327423View attachment 1327414 View attachment 1327407
Interesting results for the vertical directivity! 🙂 I was wondering about the horizontal results, but that doesn't look all that great?
Usually, the horizontal is pretty close to the directivity graph of a single driver (for a single row of drivers in an array). So I can't quite follow what's happening here?
The vertical directivity looks great in comparison. If I find the time I'll run some sims with the TC9 out of curiosity.
I don't mean to sidetrack this thread, but I've a question about oval drivers like these. Why do some of them have rectangular magnet structures like the ones shown here? When a company that spends on research, like Sony does, uses them, there must be a good reason. Are they trying to increase the magnetic strength in the VC gap, aligned with the shape of the cone, so that the voice coil pushes harder on the higher mass parts of the cone? I'm curious! Cheers, Dave
Just spitballing, but it might be just for ease of installation
It might be installation, but in most of the oval speaker/round magnet types I've seen, the magnet has still been less than the width of the narrow part of the oval... Anyway, as I say, I don't mean to hijack this thread, it's just something I'm curious about!
It is probably quite easy and cheap to manufacture a circular magnet, and it is probably quite easy and cheap to manufacture a square/rectangular magnet. An ovular magnet on the other hand, I would assume is fairly more expensive and difficult to produce. So, by my guestimation, size constraints + ease of installation + cost to manufacture = rectangular magnet. I would be astonished if they arrived at that shape for sound quality reasons, for something like a TV speaker
Yes, it is an option. 42 drivers would be needed per column. I gain in frequency response because the cancellations will start at a higher frequency, but I lose in horizontal dispersion compared to drivers mounted vertically, with a narrower profile. I will simulate, compare and rely on your opinion and experience before spending time and money on MDF and assembly.
Dispersion can be improved with toe in, frequency response cannot. But it has its price.
