OUTPUT fets heat up, why?
Original fets were FQP34N20
- 200V
- 31A
- 2370 input capacitance
- 75milliOhm RDS
I replaced them with IRFB31N20D.
- 200V
- 31A
- 2400 input capacitance
- 82milliOhm RDS
Gate resistors are 47ohm.
Attached is a photo of the switching wave of the output fets. There are 2 banks with 4 mosfets in each bank.
Right now I put one mosfet in each bank to test.
The fets heat up a little bit. The switching of the fets looks good? Or do I miss something here 😀
Not supposed to get warm? Are you testing with no load?
Is this a switching amplifier (class-D)? Or is that wave form a square wave output? Voltage rails? What is switching frequency?
You will have switching losses, which is heat, but the driver should also get a little warm...
