We used the 18SW115 in the othorn
The cabinet plans are in $325 Lab 12 based PA tapped horn. ~35hz extension posts 455, 456 and 457 (bracing). We used a lot of screws during the build to ensure no rattling or harmonics.
The Scientific cab was designed to be used either as a keystone or a tapped horn. We built the tapped horn version.
I was asking how the Othorn cab was built. Not other cabs
If the construction and sealing of Othorn cab is not good it will not perform like intended. 18sw115 is a step down from the 21sw152 driver it was designed for too.
Thanks,
