I have had a few 1500bd amps go into protect with switching the switches back and forth. I usually replace the switches when this happens. Also, you need to in install a piece of kapton tape underneath on switch towards the corner because there is a pass thru solder connection that sometimes can short to the housing of the switch and cause catastrophic failure on the fets. The tape needs to be installed from underneath the switch to R50.
