Orion HCCA5000.1DV2
Amp powers up and plays fine .
The problem with the amp is it will play fine then protect them play fone for a day or 2 then protect .
It will sometimes play/protection over and over again .
The guy stated that the amp has been back to Orion 3 times for the issue but they said the amp works correctly .
I can’t get the amp to do this either .
I noticed if I hook the amp up with no rca jacks just power ground remote and speaker I can hear a faint ticking through the test sub .
When I hook the rca jacks up to the amp I get a loud humming through the test sub .
I also noticed I have half a volt of dc measured directly across the speaker terminals and also half half a volt of dc on the rca shield grounds .
Any ideas ?
Signal source is connected to same supply as the amp .
Rca shield grounds are intact inside head unit .
With black probe on amps main ground terminal I get -0.52 volts on the rca shield grounds of the amp
I also get -0.52 volts on all pins of the opamps besides 4 and 8 which are +- 12 volts
If I use the secondary center tap I still get 0.52 volts on the rca shield ground .
With the scope set to 2 us 5 volts div this is what I get on the rca shield ground
I removed some of the clamps already was gonna pull the board out to check the bottom side of necessary.
This is the only grounding point I see on the board .
Photo 3
