Hi everyone,
I have a orion hcca 2100 that I repaired..... partially. The mute mosfets are not getting turned on, I have the opamp output but the mute fets off..no output. does anybody have had this problem. Any help appreciated. When I remove them I have output.
Thank you,
Raf
Thank you,
Raf
gate terminal has just 10mV measuring from 12V gnd. and see no voltage getting to drain or source either. Can't find what feeds the drain voltage either. I hate working without schematics😱
What's the resistance between the RCA shield ground and the primary ground with no RCAs plugged into the amplifier?
Thanks Perry for all your help. optocoupler and all circuitry around was fried and that was the reason for muting the mosfets. Schematic helped a lot
- General Interest
- Car Audio
- Orion HCCA 2100 MUTED OUTPUT
