orion 2150 power supply op amps
amp draw isn't excessive, it peaks at around 1.6amps before the led dies out and it stabilizes at ~0.2amps
weird thing i just noticed is that when i have the meter on dc voltage and i'm testing for frequency on pins 9 and 10 it shows 0hz and like 4.4vdc. now when i try it with the meter on ac voltage like you say i get 20.6khz on both pins 9 and 10 and ~4.6vac
After the supply has shut down its12.468vdc on the end closest to the positive power cable and 3.7285vdc on the other end. When the led is first lit it's 12.4 689 DC on the positive cable end and 3.733vdc on the other. I should ask, is this with the 6488 out still or back in?
