Origin of the so-called "Blumlein Garter"
The nice thing about cross-coupled cathode bias is that it almost guarantees matching idle currents no matter what the gm is. This is great for tube rolling -you can make a PP output stage that will take loads of different tube types with no adjustment necessary, even dissimilar tube types if you're feeling wacky!
Personally I wouldn't call it a 'Davis' anything. It's just cross coupled, with different iterations produced by different people. Broskie does have a habit of making up new names for common things, but then, the man thinks current flows the wrong way so :rolleyes:
All credit to Stephen Keller for hunting out the earliest patents. The man's a blood hound.
Yup. I sidestep all that skullduggery and simply call it garter bias.
My current EL86 design uses it, and it works great! As does the flea amp in my signature. Past experience shows it's great for low mu types like the 6AS7G as well.
Anybody that is skeptical should definitely try it. It's perfect for bulk lot Russian tubes that may be all over the place in gm. I'm going to work on a PCB design using it on the output stage that will work for EL84 types, good way to use the nice affordable 6p14p, and I might do an octal version for 6V6/6L6 types too.
None of you are newbies, but for their sake: Be sure to put in the grid leak resistors too. And if the one tube is gassy, or if the grid leak resistors are too high of a resistance, then we can remember the old lyric "run run run run runaway".
Incomplete schematics like the one at post # 3 get the newbies in trouble.
I am sure all of what I said now has already been said on this thread, but I started reading it today from the beginning. Could a newbie do that too?
As far as having balanced currents in the output transformer, you can use a couple of current sources for the cathodes with a couple of bypass capacitors. Oh, wait, that may not be true for tetrodes, pentodes, and beam power tubes. That is because the screens of two tubes do not necessarily draw the same current. Oh, are we back to either matched tetrodes, pentodes, beam power tubes. Or you can triode wire them, and the cathode current will equal the screen plus plate current. Or more simply a pair of unmatched triodes (they will have the same quiescent current, even though with signal the unmatched nature of the two will show up). Hmm, I guess there is a reason to use matched tubes.
