Hi Bill, I think I have your work email address, is that OK? I assume you are still there? last email was in sep 2006!!! you had changed jobs by the looks of it. I'll send you a PM to check 🙂 The email address you have for me is no longer active.
Yes if you are using a generic opamp in LTspice then it is an ideal opamp so totally devoid of any real world characteristics, TI has a lot of models available so the OPA627 should be on their site I suspect. The file I send you should help with working out how to do that I suspect 🙂 I've been through the same, started off with what ever was available, and just did ac analysis, then moved on to getting models for the parts I have and doing transient analysis. It's a powerful tool provided you recognise it has limitations and is a bit too perfect 🙂
Tony.
Tony.
Thanks, Tony. You can send me email via this site. My old email was long gone.
Unfortunately, TI has only TI part models from my memory. I have never seen the opa627 model.
TI bought Burr Brown a while back so have all of the BB stuff. 🙂 Precision Amplifier - Low Offset Voltage - OPA627 - TI.com scroll down to the bottom and go to the pspice link.
I'll send you an email but you'll have to reply before I can send the attachment because you can't send attachments though the forum email system 🙂
Tony.
Tony.
Spice op amp macromodels seldom use good input Q models - often no nonlinear junction C at all so they do not give good indications of the cm input nonlinearity distortion
http://www.sg-acoustics.ch/analogue_audio/ic_opamps/pdf/opamp_distortion.pdf has measurements - the OPA627 is unusually good with its Difet input Q
you can get around the problem by "cascoding" the whole input op amp by bootstrapping power supply pins at considerable circuit complexity
Supply Bootstrapping Reduces Distortion In Op-Amp Circuits | New operational amplifiers optimized for high-performance audio and ultrasound applications combine extremely low total harmonic distortion plus noise (THD+N), -130 dB, with large output vo
Perhaps you could use an ideal high-gain controlled voltage source combined with two big junction diodes as the op-amp model, one big junction diode from the positive input to the negative supply and an equally big junction diode from the negative input to the negative supply. Choose the junction diodes to have a capacitance of a few pF. It won't match the real op-amp very well, but the trends will be the same.
http://electronicdesign.com/article...tstrapping-reduces-distortion-in-op-amp-.aspx
This model may be better than most...
extract from the E version of the model:
Tony.Code:* DIFF INPUT CAPACITANCE CDIF 1 2 8.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 7.0E-12 C2CM 2 99 7.0E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 ******************
those are linear C unless there is a model statement or a poly def - won't show nonlinear effects
OK thanks jcx,my knowledge of the elements of a model is limited, but I could see that it had much more than the usual models I've seen in the past 🙂
Tony.
Tony.
I have just done another active line level crossover network again. The result to me is very obvious. The DC offset of the opa627 increases along with the difference increase of the +/- input impedance. However, when it is used in a buffer, i.e. a piece of wire goes from the -input to the output, the DC offset remains low, even though the +/-input impedance is not matched.
Can somebody give an explanation?
If the amp has a gain of 10, the DC offset will be multiplied by that. So if a opamp with a gain of 10 has a 6mV offset, if it is then configured for unity gain it will have an offset of .6mV.
PS. The OPA637 model is much more detailed... Here is a copy I modified to have the GBP of the OPA627 (but I may have messed something else up in doing so):
Unfortunately it seems nonlinear input capacitance is still not modeled. However if you look at the datasheet the inputs are cascoded so the input capacitance should be linear...
- keantoken
Code:
.SUBCKT OPA627_k 1 2 3 4 5
C1 11 12 2.5E-12
C2 6 7 16.75E-12
DC 5 53 DX
DE 54 5 DX
DLP 90 91 DX
DLN 92 90 DX
DP 4 3 DX
EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5
FB 7 99 POLY(5) VB VC VE VLP VLN 0 552.6E6 -60E6 60E6 60E6 -60E6
GA 6 0 11 12 1.810E-3
GCM 0 6 10 99 2.868E-9
ISS 3 10 DC 486.0E-6
HLIM 90 0 VLIM 1K
J1 11 2 10 JX
J2 12 64 10 JX
G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 1.6E-6
G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 1.6E-6
R2 6 9 100.0E3
RD1 4 11 552.6
RD2 4 12 552.6
RO1 8 5 54
RO2 7 99 1
* RP 3 4 4.286E3
RSS 10 99 411.5E3
VB 9 0 DC 0
VC 3 53 DC 2.700
VE 54 4 DC 2.700
VLIM 7 8 DC 0
VLP 91 0 DC 55
VLN 0 92 DC 55
* OUTPUT SUPPLY MIRROR
FQ3 0 20 POLY(1) VLIM 0 1
DQ1 20 21 DX
DQ2 22 20 DX
VQ1 21 0 0
VQ2 22 0 0
FQ1 3 0 POLY(1) VQ1 5.38E-3 1
FQ2 0 4 POLY(1) VQ2 5.38E-3 -1
* QUIESCIENT CURRENT
RQ 3 4 7.5E4
CDIF 1 2 8.0E-12
C1CM 1 99 7.0E-12
C2CM 2 99 7.0E-12
VN1 61 0 0.6
VN2 0 62 0.6
DN1 61 63 DY
DN2 63 62 DY
EN 64 1 63 0 1
RN1 0 65 60.3865
RN2 65 66 60.3865
RN3 66 0 120.773
RN4 0 67 60.3865
RN5 67 68 60.3865
RN6 68 0 120.773
.MODEL DY D(IS=1E-15 AF=1 KF=73.4E-18)
.MODEL DX D(IS=800.0E-18)
.MODEL JX PJF(IS=500.0E-15 BETA=3.37E-3 VTO=-1)
.ENDS
- keantoken
OP-AMP distortion can come from an imbalance of the ltp.
so the impedance needs to be matched to match DC currents.
you can easily measure this by output offset.
so work to minimize the DC offset for lowest distortion.
I have now tried matching two of the opamps at DC using the method prescribed in one of the early pages.
I found that for opa627 buffers the DC offset is the smallest when the negative input is connected to the output via wire, i.e. no matching is required. I am happy for this finding.
opa627 due to the input impedance much higher than the other all, there is no need to match the impedance ...
You must pay special attention to minimizing impedance such as bi-polarities ...
627 is an exception and a miracle in the chip ...
afshin
afshin
I noticed with discrete differential buffers if the two don't have identical input resistors then the DC bias can drift a bit.
If you are using quite a bit of gain it can be quite high.
- Chip Amps
- opamp matching +/- input impedance necessary for buffer?
