Why would you say so?
The current Hakko's and Weller's are not what they use to be.
Ok, so use and enjoy the old time gear while you can.are not what they use to be.
But do not expect others to follow suite...
In other words - after "50 years of soldering"
https://www.diyaudio.com/community/threads/onkyo-m-505-recap-project.407293/post-7574527
you still cannot solder properly...
Over and out from this thread.
I took the cover off and ran it until it stunk. Unfortunately, it is the most important cap on the boards, and the most difficult to solder do the having a wire attached to the positive terminal, and a thicker wire running underneath the negative terminal.
These caps are the only caps that happen to be Nichicon KZ's. The ELNA Silmics appear to be unphased.
