One of the best RIAA Network capacitor - for me unknown Brand
Because you don’t need a high voltage rating. What you need is high value accuracy and low tan d.
With regard to the operating values at this place of the voltage occurring, this is correct. I haven't heard from solid state phono stages (op-amp or discrete) with voltages in this area. Even in tube amps lower voltage occurs.
But in order to get best sonic performance very high voltage capacitors in the RIAA network are better than low voltage, because the heavy wight of such HV caps provide low-microphonic character, especially in high impedance RIAA networks.
Unfortunately such caps are in most cases only suited for new RIAA tube projects due the larger space requirements.
P.S.: The question in post #14 was not this. I want to have the values of tan δ and others of this caps from "db".
Reactions: Dave Cawley
I specifically use high voltage styrene caps in riaa stages. All the good stuff you want regarding electrical properties and tolerance and unlike the tiny little blighters they don't self immolate on the end of a decent soldering iron, due to the larger plate and thermal mass.
Reactions: Boydk
You can always try ex-Soviet K72-7 - they are in a box, so maybe stacked which was last that polystyrene took ( in a internal design form ).
They come in 0,5% - 2,5% @ 250 Vdc.
Small values up to a few nano.
There are S+M stacked orange boxed polystyrene's said to be the best of the bunch.
For RIAA networks.
Nah, just pad the values with pf sized wima. Buying a big batch and matching is often cheaper than trying to source 1 or 2% parts.
You don’t use high voltage rating capacitors for RIAA networks.
Every designer should consider potential failure pathways in valve amplifiers. While I generally agree with you, it is not wise to use 35V rated capacitors if a potential failure (or lack of valve in a socket) might apply 200V to capacitor.
Of course, 35V capacitors are generally not terribly expensive to replace, but when a capacitor fails in a catastrophic manner the 'smoking amplifier' effect can become overwhelming.
some of your DALE 2317's look like they are flaking enamel... but that might just be cosmetic.
I definitely trim using pf caps. Some like to use polystyrene, but to be frank and honest I find polypropylene and tin foil caps, trimmed with silver mica to yield the best 'sounding' results.
And yes, I know Morgan Jones prefers polystyrene.... Maybe in his amplifiers with his speakers, etc. they work. For me they are a pain and just sound meh...
I talked a bit by phone and have heard follow:
The logo "db" is an abbreviation.
The associated brand name was the German surname (family name) "DörrBeck" - a small German manufacturer of high quality capacitors, mainly for the use in horizontal fly back stages (around the "BU" transistors in televisions).
A picture you will find in post #1.
This brand wasn't purchased or overtaken by a new company.
This means, that the background knowledge of this company isn't available for others.
There are no brochures, folders, datasheets, publications or other printed material on the web.
This means, only the released reports (news) and advertisements in vintage electronic magazines from those days is available.
Perhaps one of the members can look for this (1970s and 1980s).
in the thread
http://www.diyaudio.com/forums/soli...rrently-available-electr-audio-magazines.html
I have listed some magazines.
any news ?
