With regard to the operating values at this place of the voltage occurring, this is correct. I haven't heard from solid state phono stages (op-amp or discrete) with voltages in this area. Even in tube amps lower voltage occurs.Because you don’t need a high voltage rating. What you need is high value accuracy and low tan d.
But in order to get best sonic performance very high voltage capacitors in the RIAA network are better than low voltage, because the heavy wight of such HV caps provide low-microphonic character, especially in high impedance RIAA networks.
Unfortunately such caps are in most cases only suited for new RIAA tube projects due the larger space requirements.
P.S.: The question in post #14 was not this. I want to have the values of tan δ and others of this caps from "db".
No they aren’t. They don’t come in high enough precision.high voltage capacitors in the RIAA network are better
I don't understand this term: "They don’t come in high enough precision."
in order to provide low tolerance or low sonic precision while performing a listening test ?
You can always try ex-Soviet K72-7 - they are in a box, so maybe stacked which was last that polystyrene took ( in a internal design form ).
They come in 0,5% - 2,5% @ 250 Vdc.
Small values up to a few nano.
There are S+M stacked orange boxed polystyrene's said to be the best of the bunch.
For RIAA networks.
For RIAA networks.
@ tief, 450v is good enough. No need to go crazy. Uk ebay has a huge selection currently in the 1n to 30n range, cheap prices too. I stocked up a few months ago.
You need 2% precision or better for accurate RIAA.I don't understand this term: "They don’t come in high enough precision."
Nah, just pad the values with pf sized wima. Buying a big batch and matching is often cheaper than trying to source 1 or 2% parts.
Every designer should consider potential failure pathways in valve amplifiers. While I generally agree with you, it is not wise to use 35V rated capacitors if a potential failure (or lack of valve in a socket) might apply 200V to capacitor.You don’t use high voltage rating capacitors for RIAA networks.
Of course, 35V capacitors are generally not terribly expensive to replace, but when a capacitor fails in a catastrophic manner the 'smoking amplifier' effect can become overwhelming.
Agree! I select for much closer precision than 2%, and it is sometimes useful to trim values of resistors and capacitor networks.You need 2% precision or better for accurate RIAA.
some of your DALE 2317's look like they are flaking enamel... but that might just be cosmetic.Nah, just pad the values with pf sized wima. Buying a big batch and matching is often cheaper than trying to source 1 or 2% parts.
I definitely trim using pf caps. Some like to use polystyrene, but to be frank and honest I find polypropylene and tin foil caps, trimmed with silver mica to yield the best 'sounding' results.
And yes, I know Morgan Jones prefers polystyrene.... Maybe in his amplifiers with his speakers, etc. they work. For me they are a pain and just sound meh...
Still using technics DJ turntable with ortofon concord pick-up? ok... then styrene caps are fine for RIAAThere are S+M stacked orange boxed polystyrene's said to be the best of the bunch.
For RIAA networks.
I see; the term therefore referred to the required precision in relation to the minimum necessary tolerance. But this isn't an issue, because this precision can easily be achieved by measuring and selecting different capsYou need 2% precision or better for accurate RIAA.
any news ?I talked a bit by phone and have heard follow:
The logo "db" is an abbreviation.
The associated brand name was the German surname (family name) "DörrBeck" - a small German manufacturer of high quality capacitors, mainly for the use in horizontal fly back stages (around the "BU" transistors in televisions).
A picture you will find in post #1.
This brand wasn't purchased or overtaken by a new company.
This means, that the background knowledge of this company isn't available for others.
There are no brochures, folders, datasheets, publications or other printed material on the web.
This means, only the released reports (news) and advertisements in vintage electronic magazines from those days is available.
Perhaps one of the members can look for this (1970s and 1980s).
in the thread
http://www.diyaudio.com/forums/soli...rrently-available-electr-audio-magazines.html
I have listed some magazines.
Maybe anywhere here is to find the wanted information.I talked a bit by phone and have heard follow:
The associated brand name was the German surname (family name) "DörrBeck" - a small German manufacturer of high quality capacitors, mainly for the use in horizontal fly back stages (arround the "BU" transistors in televisions).
There are no broshures, folders, datasheets, publications or other printed material on the web.
about the thread
BTW - the colloquial term for this device here in Germany by the most suppliers was "Booster Kondensator" (PLASTIC FOIL BOOSTER CAPACITOR by the supplier DÖNBERG). Today the colloquial term would be "Snubber Capacitor" - so I think.
The currently available substitution are the WIMA FKP versions, unfortunately not available with axial leads.
Are MKT, brand is Dubilier.
https://elektronik-lavpris.dk/p117410/1500v-22nf-booster-capacitor-20-10x20mm/
- Analogue Source
- One of the best RIAA Network capacitor - for me unknown Brand
