One (1!!) transistor clapping...
tom-vdl said:
would a sowter 8540 be usable as well? It is a lot cheaper and just about the money I am prepared to spend on an experiment
See http://www.sowter.co.uk/ under pre/line amp
Perhaps. Sowter offers such little information about their transformers I'm a bit hesitant to make any recommendations. However I think might opt for something like the 4935 under Pro Audio.
It's a 1:7 microphone/line transformer.
se
Fuling said:
I guess a choke loades source follower driven by a tube VAS might be a more reasonable approach to this whole thing...:cannotbe:
It has been done before, with success.
Yeah, but the thing is, it has been done before. 🙂
I still think there's something to be said for getting your voltage gain passively. Keep the active devices as followers where they perform much better and use a step-up transformer for your voltage gain.
Since you're willing to consider doing the whole thing with more than one active device (depending on how you're wanting to consider what constitutes one device 🙂 ), how 'bout something like this:
Output of CDP into JT-13K7-A (or perhaps the Sowter I mentioned above) driving a simple JFET follower. The output of the JFET follower driving something like a 1k or 5k attenuator, which would drive a MOSFET source follower, either directly or, my preference, through a 1:1 input transformer such as the JT-11P-1.
With the input transformer, you could locate the MOSFET source follower right next to your speakers with the input transformer giving you excellent noise rejection.
se
Fuling said:
Uhm, those transformers ain´t particulary cheap, you know...:bawling:
For me this was intended to be a "just for fun" project.
The Jensen's certainly aren't. But that Sowter 4935 I mentioned previously is only 28.56 GBP which at the current exchange rate is 377.39 SEK or 40.90 EUR. The 1:1 at the output follower's input isn't any sort of requirement. Just my particular preference.
se
pinkmouse said:
Ok I'm showing my ignorance here, but I have loads of BJT power transistors, (I don't like the sound of mosfets that much), and a few Sowter 4057 1K/5KCT input trannies. Anything I can bodge together with these?
Not much with just a single BJT. The output impedance would be way too high. If you don't mind using a pair of BJTs, you could use a Darlington or Sziklai pair and that'd make a nice follower. I'm playing with a Sziklai pair and the 13K7-A with good results.
se
8W CLASS A
This one is something Fuling may like:
Only one transistor is handling the signal, it's utterly simple with little in the way to degrade the sound.
Ideally suited for a FR speaker with low Qts or an actively filtered system.
Cheers,😉
This new design has one really big problem, however. The effective input impedance, after the pot is only about 250 ohms! This loads the input pot bigtime, and is impractical as it will also load the source too much. The bias network needs to be rescaled at least 10 times, perhaps 100 times.
I take it all back! This is NOT a push pull output stage, it is single ended. It actually has a relatively high input impedance. Sorry, I 'saw' a connection where there was only a crossover. I will look first, in future, before opening up about someone elses schematic.
Not enough diodes.
Naughty,naughty....
Jean-Paul, I think SY was just kidding.
I like this new design, but it uses 2 devices, rather than one.
Not really, only one is handling the signal, the other is tracking current.
If gain is needed we can still add a xformer at the front and a bunch of diodes...just to make everyone happy, right?
Oh, I´ve seen that one before!
Sure, nothing new. It's by Thierry Gibouin.
Nice and simple, but I can´t understand how they keep control of the bias and the offset voltage?!?
It basically tracks itself, offset should be almost nil.
Note, I am by no means knowledgeable with transistors so don't shoot me if I'm off base.
Cheers,😉
