Ladies and gentlemen, I have dream...
A dream about a good sounding class A amp with about 5-6 W output power, full frequency range, fairly low distortion, descent input impedance and so on. Nothing special so far, right?
The thing is that I want to use one, no more, active device per channel. Power supply included (OK, except for the rectifier)
Did I mention that I want an efficiency of at least 35-40%??
In my dream I can visualize some items from my junkbox:
Some miscellanous power mosfets.
A box of mains toroids with a lot of different voltage/current ratings.
A pair of big EI chokes (DIY) that should function well as "Plate loads".
A pair of big heatsinks.
I´m thinking something Zen-like here, and I need all you fanatics out there to think with me...
- class A
- efficiency 35-40%??
- one active device
hmm. you want to use a big inductance instead of an ccs? i remember Nelson wrote something about that in the board some time ago. I have the problem how to set the bias in this circuit.
- one active device
Well, the SoZ has two active devices per channel.
I want one.
Why do I want one?
It would be...cool
I already own quite a few good power amps so it´s not that I need another one, I´m just doing this for the challenge.
I think the main problem will be to apply feedback that doesn´t require a stabilized power supply.
Don´t even now if it´s possible, but hey, that´s why I started this thread. If I already knew the answers I´d wait and post the results once finished...
I want one.
Why do I want one?
It would be...cool
It MUST be possible, Nelson wrote it is. You need a coil of 1H or so. It must be a kind of circuit it old tube days when they had no ccs. I search but don´t find ....
There was a design by Jean Hiraga, using a single power FET with in the drain lead a transformer from 64 Ohms to 8 Ohms. I'll see if I can dig it out.
Just last week I was offered a pair in Brussels. Damn!
Jan Didden
Jan Didden
I don´t think 1H is necessary. A while back I was messing around with a choke loaded source follower amp, those chokes where 100mH and they worked fine for an 8 ohm load.
I too have read something that Nelson has posted here about some choke loaded Zen, but I can´t seem to find it. Though, I remember he wrote something about feedback problems with unregulated DC, and looking at the (imagined) schematic, it seems logical.
janneman, do you mean this one?
http://www.bonavolta.ch/hobby/en/audio/2sk135se.htm
Looks like something that I could rip...
Changing some voltages and currents and replacing the OPT with a choke and some output caps. Oh yeah, a coupling cap in the feedback loop, nothing fo the puritans😉
Fuling said:I don´t think 1H is necessary. A while back I was messing around with a choke loaded source follower amp, those chokes where 100mH and they worked fine for an 8 ohm load.
How 'bout take your choke loaded source follower and hitch a step-up transformer to its input for voltage gain? A follower would be more linear and the only thing I can think of off the top of my head that could be a problem would be the gate capacitance of the MOSFET.
The Jensen JT-13K7-A would be a good choice.
se
what do you think about this schem
parameter
generator: 1K Ohm amperes: 2.618 Amp
device: IRF530S power@1%2/3rd: 7.558 Watt
z-Bias: 100K Ohm dissipation: 86.39 Watt
Bias Voltage: 25.2 Volt rendement: 8.749 %
z-source: 8 Ohm gain: 0.908 x
output capacitor: 4700uF Z-out: 0.2588 Ohm
supply: 33 Volt -dB @ 10 Hz: -0.6614 dB
z-speaker: 8 Ohm -dB @ 100 kHz: -0.0323 dB
rimple rejection: 0.648 %
THD@0.33Watt THD@1Watt THD@3Watt
0.125 % 2nd 0.223 % 2nd 0.432 % 2nd
0.006 % 3rd 0.022 % 3rd 0.079 % 3rd
http://home.zonnet.nl/tschrama/owndesign.html
parameter
aiwonsi said:what do you think about this schem
That wouldn't meet Fuling's requirement that it be at least 35-40 percent efficient. You'd need to replace that load resistor with a choke.
se
Fuling said:janneman, do you mean this one?
Yes, that's the one, Nemisis. Straight from L'Audiophile. It had a kind of cult following in the 80-s IIRW. The output transformer could probably be a mains toroid with the correct turns ration.
Jan Didden
Jan Didden
I seem to recall that they used a Tango transformer.
the transformer needs to cope with 800mA DC - no go with a mains trannie. unless you have another winding and put a compensating current through this. (but then of course you have more active devices), yes like in schematic no. 3 on bonavolta's page. i think that looks like a very interesting amp...
transformer coupled transistor amps are rare..
my new preamp has an output transformer..
so why not a nice efficient SE amp with tx coupling for my horns..
regards
keyne
regards
keyne
Transformer, choke, what´s the difference?😎
I don´t see the point of using a stepdown transformer in a solid state amp in times like this when we have mosfets that can handle enormous amounts of current.
Ok, if I had a pair of suitable OPT´s then I´d use them, but I don´t.
Instead I have a pair of reasonably big chokes (nowhere near the chokes in Circlotrons "first ever class a amp", but probably big enough) that is sort of the fundaments of this project.
The big question is: Can this be made without using a stabilized PSU?
Let´s say I copy the topology of that Nemesis amp with it´s stabilized bias voltage and AC-coupled feedback, what would happen to the current through the mosfet if the Uds voltage goes up say 1V due to variantions in mains voltage?
Hi All,
I would like to add my two cents to this thread.
For the past three years I have on and off been working on a inductor loaded single stage MOSFET amplifier. It still hasn't moved beyond the breadboard stage though. I first got the idea when I saw the schematic of a parafeed tube amp and thought "I can do this with a MOSFET and leave out the output transformer". Just as Fuling I wanted to build an amp using only one active device per channel. The first atempts were made using a aircore inductor from an old loudspeaker, which obviously lacked bass. Later I got some decent inductors and the amp now produces sufficient bass. I have included a schematic as the amp is now.
Any feedback on the design will be highly appreciated
The powersupply is unregulated and is consists of a few 16500 uF caps and a 2.2 mH aircore inductor.
Playing with the amp I have made several observations:
a) It needs some active circuitry added to it to keep the quiescence current stable. As the amp is now it is (too) sensitive to thermal drift and fluctuations in mains voltage. Unfortunately I haven´t come across an effictive and elegant solution yet.
b) The choice of MOSFET is more critical than in the Pass Zen amp (which I also build), but I don´t know exactly why. Through some experimentation I found that the input capacitance must be kept as low as possible otherwise you will get high frequency distortion. The IRF150 which worked well in my Pass Zen amp was a complete disaster in this amp.
c) The sound improves with higher quiescence current - I know this is nothing new 🙂 however it is my observation that any increase in current below 1A makes a nice difference, but the audible difference between 1A and 2A is very small. With 1A it just starts to distort a bit earlier, but a normal listening levels this is not noticeble.
- One (1!!) transistor clapping...
