On Line Tube Learning for newbies....
I am a newbie to tubes and have always been interested in these glass thingies that I keep finding but I just put them in my bits box thinking"I must read up about these devices someday".
Only recently did I discover this forum and have built a surround chipamp but tonight I found this thread and more specifically,BHD's link to boozhoundslabs amplifier and some other theory links.
Boozhounds amp is a beutiful piece of craftsmanship and I have just got to make one,so I will be posting here a lot soon with silly questions.
This forum is great.
Re: replace 12au7 by 12ax7
Originally posted by pstcho
"is that possible to replace a 12au7 by a 12ax7 in tube preamp"
I'm not the expert, but if you go to Tube Town and look up their report on preamp tubes, they suggest swapping a 12Au7 with a 12ax7 for more gain (40 vs 100). Also, Steve at Decware makes the same suggestion for one of his amps. Check out the three tubes in your tube manual.
Also aNooby hooked on tubes
New To Tube Testing
Hi, Great site here LOADED with info! My name is Stan & I'm from New York. I have a question on my B & K Dyna-Quik Model 650 & would be beyond grateful if someone could help me. I have a hundred + 6550 International KT-88 tubes and cannot figure out if my B & K has the socket for proper testing. Based on my built in chart that # falls in between two others with completely different sockets,sensitivity #'s & heater#'s. I am new to this end but not new to using tubes. Thanks & great site! Awesome info- I feel like I found a new home! If I need a new tester please let me know the best and most affordable recommendation. 6550stan
circuit safety question (noob question)
After reading this thread, I'm now respectfully cautious approaching my first project, but I also have visions of my first amplifier melting down on the workbench, the victim of cascading component failures. What are the inherent safety factors that go into a tube based amplifier circuit, how do you protect it from itself? Is it the high voltage components? What if they burn up? Is it the distance between components? If 120VAC becomes 400VDC, why not 600V if something breaks, creating a domino effect? What keeps 400V from the cabinet, the on/off switch, or the volume potentiometer ?
Also, I was looking at several inexpensive kits and it seemed clear the power supply plugs were not grounded plugs, they were two prong. I would have expected a grounded plug to be fundamental for safety. Why or why not?
On test equipment, there are references to a "signal generator" - does a Hewlett Packard 200CDR "Wide Range Oscillator" count? The range is 5 - 600,000 Hz, I've used it to test frequency response in speakers. If not this Oscillator, what should I look for, something that can do shaped waves, such as square or saw tooth, as well as sine waves? I also have a surplus HP1220A Oscilloscope and an older HP141B OScope with 1423A Time Base and 1402A Dual Trace Amplifier - will these be worth renovating? Or is this type of equipment 'old school'?
When you test an amplifier for quality of output, how much do you depend on the test equipment compared to listening tests, and how accurate can you get at all gain levels? Do you expect to see
a) low noise (of course),
b) accuracy at the output stage from 20 - 20,000Hz at some gain levels,
c) accuracy at the output stage at all gain levels,
d) a nice sounding amp, almost regardless of what shows on the oscilloscope?
Thanks much -
Slow learner ...
I have been reading a lot of info and documents about tube amps ... but I still don't fully understand what makes a good tube combination.
In a 2 stage amp, what makes the input/driver stage couple well with the output stage ?
In a 3 stage amp, what is the right combo, and are there rules to follow for stage amplification factor ?
I do understand how each stage is build and calculated, but I found little info that explains stage coupling. Can you please guide me to some specific documentation or maybe explain what the parameters that guide stage coupling ?
Re: New To Tube Testing
B&K 650 settings; (picture) (Tube/Heater/Socket/Section/Test-Pos/Good-Bad/True GM/Std.GM)
Do you not know; It's illegal to have hundred+ KT88/6550 in one house... :clown:
I would like to buy a few 😉
Arne K
Basic question from clueless newbie
In a bi-amped system with one valve amp and one solid state (of roughly equal power) to choose from, would it be preferable to use the tube amp for high frequencies and the solid state for the low end, or vice versa? (crossover freq: 300Hz).
Thanks - I hope this isn't a controversial point, and that there is one, simple answer 🙂
