Isolation Transformer/Variac safety (ground): Tech Tips Tuesday, Isolation Transformer and Variac Safety - YouTube
Very good starting point for the maths of tubes:
Heinrich Barkhausen Valve Equation - ppt download
Tube Theory
#1 Tube Theory part 1 - YouTube
#2 Tube Theory part 2 - YouTube
#3 Tube Theory part 3 - YouTube
#4 Tube Theory part 4 - YouTube
#5 Tube Theory part 5 - YouTube
#6 https://www.youtube.com/watch?v=uqiwByMC5oI
Phase inversion: https://www.youtube.com/watch?v=vmKil0fb1TQ
Tube classes: https://youtu.be/Uma-cZqIhYc
AC.. There's also a second on AC with a calculus section too -
#1 https://youtu.be/Exl7p7OGnxA
Uncle Doug has a youtube channel explaining very clearly and simply how tube amps work.
YouTube
+1 Gotta love Uncle Doug.
A couple of short videos and now I know more about how tubes work than I did after reading 2 books.
He assumes the viewer knows nothing. Very refreshing and unique.
How cool is it that OPTs actually do double duty as filter chokes for the B+? I had no idea.
Just a word of caution for OTL owners that think up-sizing the output cap is a non-risky thing todo.
Having a PSU cap and an output cap without any resistance between them except the valve will measure happily with no signal. Your tube will show the idle current no problem (ie no plate resistor for example).
As soon as you have large transients or larger signals, the caps act as power reserves. So each 330uF 450V cap will happy put ±10mA to the tube current. What may read 50mA through the resistor at the cathode supply, may actually be putting out far more (depending on capacitance).
In a LTspice sim, it's very easy to demonstrate this and have an idle current of 30mA but have a peak signal transient of over 140mA given an over sized grid signal.
So check your schematic first or you may end up reducing the live of your valves or putting your speakers/headphones at risk.
Selecting components
* Capacitors
* Resistors
This is a great starting point: https://www.waynekirkwood.com/image...alls_Grant_Wurcer_Analog_Dialog_17-2_1983.pdf
He also has a mine of information on capacitors and the differences between caps - measured rather than surjective opinion: Index of /images/pdf/Cyril_Bateman
It's interesting that different types/brands have different secondary and third harmonic distortions adding to the noise and the bi-polar electrolytic is far less (although he also covers the 'diode' threshold effect) noisy than polar caps. He also covers the impact of bias on noise.
* Capacitors
* Resistors
Have to agree that Uncle Doug is great. He really breaks stuff down without making me feel dumb for not already knowing it. And he sounds a bit like Adam West (Original Batman)
Also Marks videos on Blue Glow Electronics Youtube are great. Sometimes he gets a little rambly and can jump too quickly between sections but I still learnt heaps watching his videos.
David Tipton on Youtube also has some great repair videos of old radios and quite often explains his equipment and methods and shows a full repair. Not just a puff of smoke and finished. He shows mistakes and all and how he traces his mistakes.
No so much todo with YouTube but a very interesting and explanatory article on resistors and noise:
https://www.eetimes.com/strategies-for-minimizing-resistor-generated-noise/#
U.S. Signal Corps 1-470 training film: "Vacuum Tube Electron Theory and the Diode" (1942)
new digital transfer (HD quality):
VACUUM TUBE TECHNOLOGY (U.S. Signal Corps. Radio Electronics Training 1942) Rectifiers, Valves - YouTube
older, standard definition transfer:
1942 ARMY RADIO TRAINING FILM “ ELECTRON THEORY AND THE DIODE TUBE ” VACUUM TUBE ELECTRONICS 72782 - YouTube
Hope you will give my channel a look. I'm creating content on learning about tube amps and explaining how my DIY projects work as part of the process.
Skunkie Designs Electronics - YouTube
I watch your videos and really like how you explain things. Keep up the good work
Maybe you could help me with a new to me tube amp. It’s the Monoprice IIIP Bluetooth model with EL84 tubes. I’d like to see what kind of high end tubes would work in it.
A great little page- covering OTL. The reason this is good is it shows how to design and select the right output impedance. Both calculating it and then applying it. It covers all the otl designs (not just circlotron) and does a comparison between atma-sphere and corvi mkII designs.
Hiend Audio, DIY, Hi-Fi, Stereo, Electronics site, for lovers of high-fidelity music reproduction. High-End Vacuum Tubes. Silicon. Do-It-Yourself Audio Systems. Schematics: amplifiers, speakers, horns, CD, DAC. Circuits, Topologies, Acoustics, Cables, Speakers, Voltage Regulators, Equipment Upgrades, Modifications, Problems, Solutions, Tips, Tricks. ------ Dla pasjonatow Hiend Audio, najwyższej wierności odtwarzania muzyki na sprzęcie budowanym, modyfikowanym samemu. Wiedza: elektronika, układy lampowe i krzemowe, wzmacniacze, głośniki, kolumny, tuby, DAC, kable, DIY, porady, sztuczki, problemy, rozwiązania, tor audio.
A little more advanced - PSRR in differential and Circlotron/PP forms:
First let’s look at “aikido” with a simple differential stage:
Aikido Differential Amplifier
Now let’s look at more advanced, there’s reference to Broskie’s Brazilian OTL but he provides the full schematic for study. Ignore the solid state followers, but if you follow the first link this should be straight forward:
Fancy Box and OTL Downshift
Also bumped onto this for the SE folks: Lowering SE Amplifier Noise (page 2)
For those wanting to see an example of building an amp from load lines to complete chassis, then I would recommend having a look at this very clear article as an example:
With respect to Nobu Shishido. KT88-based Push-Pull Amplifier
If you've not seen this: Understanding Audio then it's possibly a good place to start
it has some very good explanations about things like negative feedback, cathode degeneration and what that does to both input impedance and output impedance.
yes, there is an internal cathode resistor represented by 1/gm...and is cathode current dependent, a look at data sheets will show...
plate resistance rp, otoh is plate voltage dependent, again looking at data sheets...
mu =gm x rp, but mu just like the pi in a circle does not represent a physical representation...
mu in a triode is quite low, except perhaps the 6jd5 which can be in the 300 range..
mu in a pentode is so high that it is not used in any calculations and is largely ignored...
- Tubes / Valves
- On Line Tube Learning for newbies....
