Greets, Please review what I have you logged in for at the moment and advise of changes needed.
I recognize the need to clarify the particulars of the led sets. I will do so shortly.
I still need the mailing address for 7 members.
Ichiban, please clarify your interest in led's.
At this time I will no longer consider supplying 2SK170's
member.........relays.....led sets...address needed
Russellc............7...........1
thefragger........12
stoolpigeon.......10..........4
PierreQuiRoule...21..........3............need
jimbop..............7.........................need
mlloyd.............12
Thror...............7.............1
fastvideo.........25
number9..........10
aud1out..........25
guglielmope.....10..........................need
Praudio...........24..........................need
1MOR.............10
BDP...............12
ICHIBAN.........12.............?
jims...............14...........................need
wirewiggler.....14.............2
mekanoplastik...9.............3.............need
ujamerstand....14...........................need
number9..........10
aud1out..........25
1MOR.............10
Wow... what are the LEDs for and how are they matched?
Thanks for all your hard work in getting this together for the community, Ed!
Hi Ed,
to my order for 12 relays please add enough leds to do 4 boards.
thanks
leds and cost
I'll be measuring the voltage drop across individual leds and combing them into strings with Vf values that match, channel to channel. The 5 led cluster is intended to drop a target of 9V, something less than that is acceptable. The 3 led cluster is intended to drop ~5.4V. I'll be measuring to 0.01V
When you get them they will be packaged in 2 groups of 3 & 2 groups of 5 for each board. Don't mix them if you want to retain the match between channels.
I set the table and y'all come to eat. 😀 We're almost up to 400 leds now. I'd better figure a cost...🙄 I believe once I get set up I can blast through them in 5-6 hours.
How does $4.50 per set of leds strike you?
In the words of Salas: the leds are an "Alternative and more precise to a resistor"thefragger asked:
Wow... what are the LEDs for and how are they matched?![]()
Per Tea-Bag's caution, the leds are 20ma.
Thanks Tea!
Invoices are soon on the way.
I want to order relays on the evening of Nov. 17. Please respond before that time to be included in this effort.
Newcomers are welcome until that time, after which I may turn into a grump 😡
Thanks Tea!
20 invoices have been sent...all by pm.
Please respond with confirmation or adjustments to your invoice.
😀 If you catch me in a mistake you are doing the work of 2 people. 🙄
rsotirov, you are on the list.
I have no response / confirmation from:
jimbop
fastvideo
guglielmope
ICHIBAN
jims or
dshambala
Check your pm and respond to your invoice, Please
jimbop
fastvideo
guglielmope
ICHIBAN
jims or
dshambala
