Okay, probably a dumb question, but can anyone advise of safest way to fit a pulley?
Pulley fit
In general, I typically heat the pulley to expand the bore and drop it over the shaft.
If you must press, you must do it in such a way that you press straight, with even controlled pressure and not transfer the thrust through the bearings.
Cyclotronguy
Remax ?
Hi Copydex,
which Remax are you using is it the 226764 as
mentioned by Mark Kelly ?
or 226779 ?
I'm fitting a new motor to my Oracle Delphi and I'll be running it from a bench supply until I make a better motor supply.
I got a mate to turn me a motor pod from a lump of oak.
Regards, Jules
