O2 amp parts GB, EU
I have started packaging the parts, but I haven't gotten very far.
Still trying to figure out a way to organize all the bags on the table 🙂
Because right now it takes me 10+ minutes to package and double-check single kit.
Regards,
Jokener
Hi Jokener
Don´t know how far you got until now but let me give a hint :
Get a pack of that "throw-away" plastic party pots and a decent scale with 0.1 gramm accuracy.
Put all pots in front of you on the table and count the parts to the exact amount of pots. Then start filling the pots with the parts. If you come out 1 short or 1 to much you know you have to check again.
When you are through all parts measure the weight of every pot.
I went through this several times for my employer and this kind of work is APITA 🙂
Hope it helps
JML
@Timpert: Did you receive the money by now?
If not I will go to my bank on monday to check WTH is taking them so long...
(It is gone from my account, so they processed the paper form I gave them.)
I'm just anxious because I have never done bank-to-bank EU-transfers before.
Regards,
Jokener
Regards,
Jokener
Didn't Timpert say just on the previous page that the money had arrived?
Ooops... I have the layout of the forum set up to always show the maximum number of posts on one page.
Didnt spot the post where Timpert confirmed the arrival of the €s.
I'll go to sleep now and puzzle a few more kits tomorrow.
@limp: Thanks for the reminder!
Interested in 1 kit if you have any leftovers. Also 1 enclosure and wall transformer (if still possible)
(EU)
I know that I'm very late for this GB. If there're no more leftovers, count me in for the next GB
Thanks for your work!
I have been busy packaging, but progress is slow.
I converted my guest room to an assembly line with a large wallpaper-cutting table...
That way I can at least have all the bags and parts on the table, but it's still very tedious (as expected, no surprise here).
Timpert did not give me any further update, so you know as much as I do.
But as per his information, I expect the transformers soon.
I also finished the calculations for the additional payments, I'll post them when an get back home.
And no, the PCB's have not arrived yet.
I will of course inform everybody of that and will also take a picture and post it.
Regards,
Jokener
I have made an appointment with the transformer company to pick up the transformers on Monday October 31. It was uncertain if they would arrive in time on Friday in order to be checked and handed over to me, Monday was a safer bet.
If I have the transformers, I will take out my two specimens and send the rest to Jokener.
I have picked up the transformers and sent them to Jokener. I have taken out my two transformers of course, and I think they turned out very nice. Jokener should get them this week, the guy at the DPD service point said that the packages will be collected tomorrow.
Transformers
Just a bit more info... This is what you'll get when transformers are on your order. I measured the no-load voltage, and it is 17.5 Volts, so this one is properly spec'd under load. It has ample voltage margin for the O2.
