NVMOS amplifier
Workhorse said:
Hi Viborg _Lars 2
Why are you so much interested in this amp....
K a n w a r
- Hello Kanwar!!
I have never experimented with FET's in A / A/B setup, only swithcing... Nor never heard a FET amp that was audible - all i heard sounded like Sxxx... - Could be fun to experiment with a nearly finished setup, refining it in different ways...
Lars / Viborg
nillerviborg said:
- Hello Kanwar!!
Lars / Viborg
Hi VIBORG LARS2😉
If you have never experimented with Vertical N-Mosfets in Class-AB mode, then how could you tell about there sonics...The ones you have heard might sxxx in there designs also.... 😀 😀 😉
K a n w a r
Workhorse said:
Hi VIBORG LARS2😉
K a n w a r
Dammit... - I almost everytime almost presses [report] because i'd guess that would be where to place reply!!! - Hope nobody or my self gotten _bad_ reports due to that... *SS
I have heard some commercial FET designs through time, never was impressed... - Till now, the reference must be Lars Clausen's Patriot amplifier, which to the not-knowing is a 100W class a balanced construction, pulling app. 700W in bias... - Nice...
Some Close-to things could be the improved JLH with CCD control instead of voltage reg. ...
Sincerely, Lars / Viborg
Hi!
Nah Kanwar bhai,
It has caught some mojo jojo says no audio device leave alone that it has corrupted the PCB software too, unable to make a pic or a prn file out of it.
Surprising a Google on it result in thousands of probs but no sure solution. A format and re install of windows was a total failure. Even external sound card is not working.
Appears it is some glitch due to updater M....soft not willing to acknowledge.
Just do a google "no audio device" and see if something can be done else will copy complete file on a different PC and do the stuff there.
Murphy is only I can say how things get stuck up.
Bole to Rahul, yeh to mujhe bhi pata hai ke amp chalega kyunki meine ise banaya hai, par yeh pcb ka jhamela kar ke meri Lassi kyon karwa rahe ho... meri ijjat ka kabada mat karo zaar...yeh sala quasi jaisa pcb mere ko achha nahi laga, tere ko apna bharat kya achha nahi lagta, apna brain bhi use kar liya karo munna bhai
mera khayal rakho
K a n w a r😀 😀 😉
