NuForce 9 Amplifier of the Year
classd4sure said:
So, it somehow took the SI amp to discredit reviewers for you? Hm. Can't say much more.
Sorry, but I do not understand the last sentence.
As said in my previous post, I do not believe in objectivity. That means I have no problem with awards like this. I know they are subjective and biased, just as this thread--the Will To Power.
I have no problem with reviews and reviewers. My problem is some people's claim of objectivity. The opposite of objectivity isn't subjectivity. The opposite of objectivity is life--the will to life. I have no use for the dead. "Let the dead burry their dead." --Jesus
If you make your audio purchasing decisions on design or technical measurements... you’re an idiot.
If you make your audio purchasing decisions on someone else’s opinion (reviews) be they good or bad... you’re even more of an idiot.
If you want to know how good and appropriate a given product is, TAKE IT HOME AND HEAR IT IN THE CONTEXT OF YOUR SYSTEM!
Just to hazard a guess but um.. well, salesman.
Bleurk
Why is one of the wires from the output common mode choke resting on the input wires?
I might also ask why the average DIY person who 'cares' might just produce a better constructed 'project'...... urm product.
Oh..... I've got it, that's why you do DIY
DNA
No, it's called common sense. The finest test instruments on the planet are those two flappy things on the sides of your head. Use them.
serengetiplains said:
"A" .... "The" .... tomahawk shmomahawk, what does Sander say?
Floor Sander Anderson need not say much.
Tell me this,
Why did
"The chief engineer of the Tomahawk cruise missile power system."
Second source some power supplies from shitville and bolt them in a box with a lack of 'skillsaw'?
DNA
Genomerics,
The SMPS they use is actually a pretty capable industrial (revolt you audiophiles, this is heresy!) design by Skynet. It is an off the shelf part, hence no engineering effort was required on their part to implement it, all they did was mount two big capacitors at the output to give it a bit better transient response.
The actual amplifier PCB is identical (!) to that of the Reference 9, which triggered my comments in the article that the Reference 9 is basically what the 8 should've been. They opted to use a better SMPS, fiddled with the dead-time a little and used a better opamp in the feedback loop of the modulator and (start drumroll) added a half-baked common-mode solution to cut down on RFI.
It did help to improve the amplifier but these are really basic tweaks any highschool student with a soldering iron can do, not 'next generation' modifications done by a pro that has worked on the Tomahawk cruise missile's power systems. If they were, and he was billing by the hour for his services I'd be inclined to ask for a refund. I've seen more extensive and better executed (read: by the book) modifications done to all sorts of equipment by members of these forums.
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
So, reading between the lines, what you are trying to say is they second sourced some power supply from shitville, like they did with the 8, and 'jackhammered' it into the box.
You want to tread carefully mate. If we got into an argument I'd be apologetic and you would not survive. (Mind you I have an inflated opinion of myself)
Oh, it was an industrial power supply. That's why it has all those extra parts on it. I was wondering.
Was that a job lot before the NuForce 10 comes out?
Perhaps a bigger box is needed.
DNA
Nope, you can't fool me, you're a salesman. 🙂
Common sense would dictate you can't take everything home and try it out, certainly not a multitude of components to compare against each other in any meaningful way. Come oooooooon. Get real. People go by specs, reviews, or any combination of the two. Welcome to planet earth.
I wouldn’t consider Taiwan Shitville :devily: Don’t blame the PSU, it is not its fault that it sits in that amp.
Cheers 😉
I guess that depends on where you live. New or used, if I can't try it I won't buy it. Specs and design are all irrelevant. My ears and my ears alone judge what sounds good to me. And if it sounds good then it is good! I don’t need to have my opinion validated by someone else.
