NP D1 DAC clone with enhancement
Attahed is the schematic with Jfet IV and low noise regulator enhancement. PCB layout completed and project in progress.
Note that Parts is still available from Ruach and I brought two sets SM5842 and PCM63PK from him.
Shall update project progress and any comment is welcome.
Spencer
  • bal pcm 63 dac 21s.pdf
Your project sounds interesting. I am planning something similar to mod my Rotel rcd991 but re-using the existing PMD100 instead of your SM5842 filter. My idea is to replace the dac and iv stage but not the filter. I am getting the data after the PMD100 in the rotel and send it to a new pcb (inside the rotel) with 2 PCM63K per channel (working in differential) and balanced jfet IV stages.
BTW After seeing your component layout, it seems you are using an external clock (tentlabs?). Is it right?
Please keep us updated.
Xavier
Boards received and will start soldering. See attached.
