It can, and should, be used. It just carries through, like the other phase of the AC line.
Slit a spot in the center of the length of a three wire IEC cord sheath open.
Cut and use the hot black conductor for the bulb, leaving the green safety, and white neutral, wires uncut.
It can and should. It just carries through, like the other phase of the AC line.
That's what I figured. I just found it strange that not a single example included one.
> I haven't seen a single DBT that includes an earth conductor.
http://www.geek-tips.com/wp-content/uploads/2015/11/C9DD5729-A545-47C3-B46C-F066C2AFAC59-copy.png
https://i.ytimg.com/vi/yfb2Ma3xmR8/maxresdefault.jpg
Dim bulb tester | Alternative Energy Circuits Blog
https://lh3.googleusercontent.com/p...G2wL7RRCaUg_Sv-CGYZDB7uX2jkml_vp5sMDkV-31dgU2
https://www.antiqueradio.org/art/Dim-bulb Schematic.jpg
https://robrobinette.com/images/Guitar/5E3P_Build/Light_Bulb_Limiter.png
https://lh3.googleusercontent.com/p...qD-eKfuqnh2vCX_C_iDhVYwn1WpfSwFxsauMsbUhALANg
https://www.instructables.com/Light-Bulb-Current-Limiter/
PRR, your googling s apparently superior to mine lol.
I used your exact term, only spelled-out (if Frabor and BSST didn't know it, Google might not either).
dim bulb tester - Google Search
Then I clicked on "Images". Not all showed grounds, but many did; took under 10 minutes mostly verifying and copy-pasting to prepare that list.
- Design & Build
- Equipment & Tools
- Noob DBT question
