I went to Madisound... no TangBang drivers. Or did I miss something?Yes. Chris got them from Madisound when i was in hospital.
dave
The box looks nice, but with the kit, you get the 5" and then an ~8" passive radiator. So wouldn't you do a closed box?https://www.diyaudio.com/community/threads/tiniest-40hz-sub.407158/post-7574293. Next box I model will be the 4L with 2x 6.5" Dayton reference alloy cones and be build to keep an eye out for. The cross-section is almost egg shape on that and the internal volume can be adjusted by any amount even after completing initial build and listening tests. My bass driver is expected to arrive this Friday and I am really looking forward to putting it through its paces
Chris would have bought them 7 years ago. No idea what we originally paid for them.
dave
The box in the pic is the bass reflex text box with 4L driver volume and 43hz portSo wouldn't you do a closed box?
Next test boxes are the passive radiators replacing that port volume. In ply, it is super easy to do half an egg cross section. In foam, even more options for shape and added advantage that the box can keep growing in one dimension at any point in its life
'HF' means different things to different people! What are the frequencies which you have found to be significant? Cheers, Carl.rarely sufficient continuos HF energy...
- Full Range
- Noob Cabinet design questions...
