No Input Select at Kenwood's Integrated Amp A-1001
The amp is to find here:
??????????????A????? - ?? - Yahoo!???
By operating both at this knob and the associated remote control there is not to observe any change of the input - only "TUNER" remains in operation.
How I can check the correct operation of the controller NEC µPD75004CU-199 ?
Is there a custom made (mask) programming applied?
The encoder looks not like that one from the first picture, but than the second picture from follow links:
http://www.mikrocontroller.net/attachment/38788/Encoder.jpg
Type No is follow: 9905400-332a (controlling by change of capacity ?)
What kind of encoder is this?
More URLs:
KENWOOD A-1001 ?? : ????????????
http://i01.i.aliimg.com/wsphoto/v0/1132010687/D75004cu-082-.jpg
Thank you for your reply, cause I’ve got the same problem and it was solved for about 300€, I think that it must be the NEC IC. I hoped that it was just the SuperCap which is simple to change. First I will do some measurements to the IC, then I must try to find a new one! The Volume/Mute is doing fine. Anyway, thanks again, very kind. Best regards from Holland.
