My friend just bought a pair of Canadian made speakers, forgot about the brand, but he claim that the speaker has no cross over.
Is this possible?
Chris 😕
Is this possible?
Chris 😕
But it was a 2 way, one tweeter and one woofer, two binding posts in the back of the speaker thou?
NO X-OVER.
I fail to see how they could get away with that really...unless they need to be bi-amped and the X-over is built into the amp or an active X-over perhaps??
Anyone?
Cheers,😉
Anyone?
Cheers,😉
It could be that the 'speakers are made by Axon, on some of their 2-way models no inductor is used on the woofer but there is still a capacitor and perhaps some resistors on the tweeter.
Tony D.
Tony D.
I KNOW THAT SPEAKER.
That must be Audio Reference 3A.
I think that speaker dates from the early nineties and I'm pretty sure a cap was used to filter the highs.
Most of the line was based on Audax units.
Cheers,😉
Reference 3A
Cheers,😉
Frank,
I think you are correct, I just found their web site, do not know whether it is Audax driver though, it sound very nice not broken in yet. Driven by a pair of very strange big tube mono amps, with five chrome plated circular covers, Mastersound something.
You don't really need crossover in a woofer (if properly chosen), and that's what I'm doing with my Triangle mini-monitors. But the cap is almost necessary in a tweeter network, if only for protection against excessive power levels.
chris ma said:The name is called Reference 3A , Canada made and French design if I remember correctly.
These are an excellent speaker -- essentially a full-range with a helper tweeter. The extended range driver has no XO between it and the amp. The tweeter has a single cap -- one of the local guys upgraded the cap in his for (he claims) better performance.
This is the scheme i always try to use. Pick a full range or a midbass with a nice controlled rolloff, and then add a tweeter with just a cap to fill in what is missing on the top.
dave
Reply
Maybe the tweeter was Audax's Gold-dome special piezo tweeter,so that it didn't need a crossover.
If you prefer a simple hifi speaker,i think a bass/midrange driver with a freq range of 40hz-8khz is good with a piezo tweeter from 1.8khz-30khz.Also a hifi speakers that sometimes use piezo tweeters,never use a resistor is series,but the pa/disco ones mostly do.
Ahh, but it does... It uses a different implementation of piezo technology, and a standard crossover ( pretty good quality actually) comes with the driver, with the step up transformer needed.Maybe the tweeter was Audax's Gold-dome special piezo tweeter,so that it didn't need a crossover.
recipe anyone?
The driver unit in this Reference 3a does not seem to be from Audax. May be I could not find it.
I may be temped to cook a pair of this sort of speakers up to replace my Mirage M490is. The M490is sounds really good now, but the upgrade bug is biting me. In order to get anything better than the M490is may mean a big leap into the $3000cdn/pr range. M490is is a full range floor standing 3 way with 8ohm nominal, Freq Response around 45Hz-22Khz. Eff.dB 89 crossover at 1.8khz
But I need all the help since I have no knowledge of speakers and no means to do any measurements. What I hope for is something along the line of 8ohm nominal, but occasional dip to 4ohm is fine with my amps.
So anyone mind trying to give me some ideas, or recipe?
Chris
Chris
chris ma said:But it was a 2 way, one tweeter and one woofer, two binding posts in the back of the speaker thou?
Arises a problem, yes? (Yoda is wearing off on me now!!) A tweeter not being burned out by being told to produce the full audio spectrum is uhh....well, uhhh, just don't try it especially if you just bought some scan-speaks. Woofer, yeah sure, Acoustic Research lets their woofers roll off naturally, sounds decent too!
So, woofer=possible, tweeter=99.9% chance of burnout.
Reference 3A
I had a pair of early Reference 3A speakers about 8 years ago. Modded them a little, too.
At that time, they were designed and build by Daniel Dehay in France. He later moved his operation to Switzerland.
The woofer appeared to be using a large Audax motor/magnet/basket assembly (w/vented pole piece) with his own doped carbon fiber hypex curved cone. The doping was thick, and looked like an epoxy decoupage. Surround was convex rubber. The woofer was directly coupled to the binding posts.
The tweeter was an Audax silk dome. There was a crossover for the tweeter only, and more than a simple capacitor. It involved a parallel resistor/cap combo in series with another cap. I don't recall the values at this late date, but seem to remember that the slope was more gradual than 6dB/octave in the crossover region.
These speakers are made to be used with the tweeters on the outside of a stereo setup, and the speakers tilted in slightly. If one were to draw an arc using one's ear as the apex, the scribed arc would touch the woofer's dustcap and tweeter simultaneously for best imaging. And boy, those speakers *imaged*!
I swapped out the sand cast resistor for a Caddock, and too the Solens, eventually settling on Black Gate BG-Ns. I also swaped out the (early) pedrestrian internal wiring with Transparent chassis wire and Cardas binding posts. I believe that the 3As are upgraded to Hovlands and Siltec these days. I also built a pair of 26 inch tall speakers stands for them that weighted over 200lbs each.
One funny note, I remember reading about how Daniel Dehay used a "special" mysterious wood product called Medite for the cabinet, with extraordinary sonic properties. I know it well, Its pressboard maufactured fairly close to me in Medford Oregon. 🙂
3A
As I said all along the spaeaker range is firmly based on the Audax range of units.
Yep.In "frog" speak it would equate to "Medite" and that is no more no less than MDF = medium density fiber board".
Cheers,😉
Cheers,😉
Re: 3A
Medite would actually be catoragized as HDF = high density fiber board. I have been using it for at least 20 years.
dave
fdegrove said:"Medite" and that is no more no less than MDF = medium density fiber board".
dave
DEPENDING?
MEDITE
Let's just say confusion reigns?
I think the name "medite" is short for medium density.
I could of course be wrong.
Cheers,😉
MEDITE
Cheers,😉
Not wrong, Frank.
"Medite" is a trademark of the Medite Corporation, located in "Med"ford Oregon.
http://www.doleta.gov/regs/fedregs/notices/98001476.htm
That's why I found it so amusing that a tweek speaker company half way around the world from me was going on and on about the superior results using this pedestrian building material from a local lumber mill. 🙂
- No Cross Over!
