2023 version of PCBCAD51 and PCBCAD720 are out now.
https://www.murtonpikesystems.co.uk
For railway modellers:
www.platformfour.uk
www.platformfour.uk
A big thank you to all those who bought PCBCAD51 through the year.
The 2023 version is out now.
Buy a download to beat the post office strikes.
Still rock bottom prices.
http://www.murtonpikesystems.co.uk
PCBCAD51 has a "swap auto-placer", this swaps around component locations until shortest net is found.
Use copper pours to add copper to an area of the pcb. Copper pour can connect to one net per layer.
This software has no bug list. If a bug is found it is fixed straight away.
Secure website at:
Secure website at:
PCB design software Condition is "New". 2023 version.
Download and software key (no CDROM needed.)
Why is a download better than a CD ? you can download newer versions as they come out.
Runs on Windows XP (SP3) , Windows Vista and Windows 7, Windows8, Windows 10 and Windows 11.
This is a mature product with no bug list, if I find a bug it is fixed immediately.
Support for this product is second to none, you are supported by the guy who wrote this software.
Schematic and PCB symbol designer wizards.
Auto creates SIL, DIL, BGA, circular and QUAD PCB footprints from your parameters.
Schematic entry with auto convert schematic to PCB rats nest, unconnected pin scanner and single ended net scanner.
PCB entry with 127 layer rip up and retry auto-router with clearance and continuity check.
Gridded and grid less auto routers.
360degree rotations of pcb components with obround pads.
Integrity checker, compares schematic and PCB for differences.
Component locater.
Parts list output to file and to printer.
Schematic/PCB component auto-renumbering and re-annotation.
RS274X Gerber file generator and NC/Excellon drill file generator.
Pick and place file generator with fiducial option.
3DPCB viewer module. (for this software output only)
Output schematic to printer auto-sized.
Output PCB to printer in 4:1, 2:1 and 1:1 scaling, inversion and mirroring about x and y axis.
Merge schematics and merge PCB's.
Library scanners for fast component selection.
Gerber file viewer (for this software output only)
Component locater, block-mode for repeats, shifts, rotations etc.
Net optimizer for shortest routes.
Auto component placers for minimum routing.
Recursive auto-autoplace, rotational autoplace and swap autoplacer.
Auto-place and route recursively function for lazy PCB design.
Unconnected pin scanner.
Forward annotation function from schematic to PCB.
Screen capture to bitmap file in schematic and PCB entry.
PCB's up to 50 by 50 inches.
127copper layers.
127resist layers.
Copper pours, each layer can be connected to a different NET.
Two silk layers (upper/lower)
Comes with basic symbol libraries, 4000, 7400, smd4000, smd7400 and general as standard.
User manual in each module
This is the full version and not a crippled, time limited or downsized version.
This is a fully integrated package and not a suite of amateur free programs cobbled together.
Fully supported package with email and phone help lines.
Component locater.
127copper layers.
127resist layers.
HI Nigel, was wondering if you might have some details about this amp board I was gifted. I know its old, but I was hoping to make a powered sub out of it.
Its an old class d amp I did a few years ago.
If you send me your email address I will send you pdf files of circuit diagram.
ckpr2@talktalk.net
ckpr2@talktalk.net
Couple of improvements to PCBCAD51 this month.
1/ Added arc function for creating complex pcb outlines.
2/ Added clearance check on text on copper layers.
I found I often edit the pcb tracks and was forever typing in layer 1/2 and width 80.
I have now added control-a to make track up to next pin layer 2 and width 80.
Added control-d to make track up to next pin layer 1 and width 80.
Added control f to make track right angled to next pin even if pins are off grid.
Added control b to make tr5ack aligned back to previous pin even if off grid.
Software has a swap autoplacer.
This swaps around same components until minimum net length is found.
On a couple of occasions this has made an un-routable pcb route ok.
Basic auto-router. Can also be made to just route simplest tracks if you want to route long ones yourself.
- Vendor's Bazaar
- Nigel Wright's Vendor Thread
