• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Nigel Wright's Vendor Thread
Runs on Windows XP (SP3) , Windows Vista and Windows 7, Windows8, Windows 10 and Windows 11.
This is a mature product with no bug list, if I find a bug it is fixedimmediately.
Support for this product is second to none, you are supported by the guy whowrote this software.
Schematic and PCB symbol designer wizards.
Auto creates SIL, DIL, BGA, circular and QUAD PCB footprints from yourparameters.
Schematic entry with auto convert schematic to PCB rats nest, unconnected pinscanner and single ended net scanner.
PCB entry with 127 layer rip up and retry auto-router with clearance andcontinuity check.
Gridded and grid less auto routers.
360degree rotations of pcb components with obround pads.
Integrity checker, compares schematic and PCB for differences.
Component locater.
Parts list output to file and to printer.
Schematic/PCB component auto-renumbering and re-annotation.
RS274X Gerber file generator and NC/Excellon drill file generator.
Pick and place file generator with fiducial option.
3DPCB viewer module. (for this software output only)
Output schematic to printer auto-sized.
Output PCB to printer in 4:1, 2:1 and 1:1 scaling, inversion andmirroring about x and y axis.
Merge schematics and merge PCB's.
Library scanners for fast component selection.
Gerber file viewer (for this software output only)
Component locater, block-mode for repeats, shifts, rotations etc.
Net optimizer for shortest routes.
Auto component placers for minimum routing.
Recursive auto-autoplace, rotational autoplace and swap autoplacer.
Auto-place and route recursively function for lazy PCB design.
Unconnected pin scanner.
Forward annotation function from schematic to PCB.
Screen capture to bitmap file in schematic and PCB entry.
PCB's up to 50 by 50 inches.
127copper layers.
127resist layers.
Copper pours, each layer can be connected to a different NET.
Two silk layers (upper/lower)
Comes with basic symbol libraries, 4000, 7400, smd4000, smd7400 and general as standard.
User manual in each module
This is the full version and not a crippled, time limited or downsizedversion.
This is a fully integrated package and not a suite of amateur freeprograms cobbled together.
Fully supported package with email and phone help lines.
Reactions: JMFahey
20 mega samples USB PC oscilloscope.
2 volt max input but 20v with x10 probe or 200v with x100 probe.
Good enough for audio up to 1MHz.
Analogue display and spectrum analyser display.
+ve, -ve and no trigger modes.
Roll mode or single shot.
£30 to UK £40 rest of world.
